3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,825
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
While building my barn pad, all the strenuous digging, ripping, fel and boxblade work has caused my shuttle shifter to not work. I bumped into a rock pile in reverse with the boxblade and the shifter got stuck. First time that's ever happened after 345 hours. After wiggling it I finally pushed it into forward and started going again, only to find out it would not shift into reverse! I could move the shuttle lever freely but it was not engaged to anything anymore...just flopped around, but the trans was stuck in forward.
So I drove the Kama back to camp to see what the problem was. Thoughts of stripped gears, broken shifter forks etc. dance in my head. To compound matters, it was raining pretty hard by now.
I was hoping it would be something easily repaired, and not a major thing. Hoping maybe it would be something that was minor and could be made better by fixing it. So I took the shifter plate that held the 4 wd and shuttle shift levers off.
This is what it looks like under there. You can see the shifters have ball shaped actuators that ride inside a channel. The channel is attached to the gear clusters and move them from one position to the other.
Didn't look like anything was broken? You can't see it very well, but the slot for the shuttle lever is closest to the bottom in that picture. For some reason, the slot walls had a big 1/2" chamfer on the right side.
