Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Elite Member MotorSeven's Avatar
    Join Date
    Aug 2005
    Posts
    4,033
    NE TENN (Hancock Co)
    Kioti DK40SE Hydro
    Default Dozer: Case 350B rock guards
    Ok, i did it, i bought a "little" Dozer. I read here all the pro's and cons, and decided to throw the dice on a '76 Case that is in overall good condition. It needs some TLC: missing a few nuts/bolts here and there, the track plates need tightining, complete fliud change, spool valve leaking a bit, throttle linkage needs adjusting. On up side, the tranny is 2 years new, rear end was rebuilt, sprockets and related trac components have very little wear showing, hyrdalic pump was replaced a few years ago, engine starts and runs strong, has a heavy duty ROPS cage. What it is missing are the rock guards....there should be 2 on each trac. I have "googled" myself silly, and haven't come up with a set, so i am hoping that someone here can give me a line on where to look, or should i fabricate some?. I have a lot of limestone rock here, so i think that they will help keep me from throwing a trac off from time to time.
    Oh yeah, it hasn't been delivered yet, so the pic's will have to wait.....
    RD
    2008 KIOTI DK40Se Hydro
    1978 Sling Blade/wood handle
  2. #2
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,469
    Tyler, Texas
    Several, all used and abused.
    Default Re: Dozer: Case 350B rock guards
    Congrats on your dozer.
    I have a Case dozer too, and have found that it's very, very hard to beat the dealers price on parts. I've tried, and for filters and hoses, Napa is allot cheaper, but for just about everything else, the dealer is pretty competitive.
    My New Holland parts guys are the best. If they don't have it, or if it's crazy expensive, they will tell me where I can get it cheaper. It never hurts to ask, most of the parts guys I've come across are pretty helpful.
    One sourse you might want to look into is to find a printed paper version of the Machinery Trader. Construction Equipment at Machinery Trader: Caterpillar, Komatsu, Case, John Deere, Volvo
    I don't subscibe to the paper, but have come across copies of it from time to time and there is a section in it that has all sorts of classifieds for heavy equipment parts. Belly pans, plates and probably rock guards. Maybe you can find something at there website?
    Eddie
  3. #3
    Join Date
    Aug 2005
    Posts
    4,033
    Kioti DK40SE Hydro
    Ok Eddie, i wll look up the local Case dealer.....thanks
  4. #4
    Gold Member
    Join Date
    Jul 2005
    Posts
    328
    pa
    Kubota L48 Kobelco sk100 Kobelco sko35 case 450 Mack R600
    Try Broken Tractor dot com or 877-509-0666 or Paint Valley Equipment @ 877-774-0081 have bought parts off both and the service and price is good
  5. #5
    Gold Member
    Join Date
    Jan 2007
    Posts
    316
    I constructed a set of rock gaurds for a D4 6U, they are not hard to make.
    Track frame removal is neccessary and if a pattern from a similar machine can be taken, fabrication will be easier.
  6. #6
    Member
    Join Date
    Jan 2007
    Posts
    46
    Turlington Tx and Llano Tx
    John Deere 5210 & John Deere 6115D
    Try KENCO Mfg. or 1-800-522-5231. They make all kinds of parts for dozers.
  7. #7
    Join Date
    Aug 2005
    Posts
    4,033
    Kioti DK40SE Hydro
    Thanks guys, i'll try your contacts also....
    RD
  8. #8
    Join Date
    Aug 2005
    Posts
    4,033
    Kioti DK40SE Hydro
    RW,
    What thickness steel did you use? I looked at a set on a Deere 450, and they had a honecomb type pattern. Would flat bar work, or would it be too weak? Any pic's of your fab? Thanks......
    RD
  9. #9
    Join Date
    Aug 2005
    Posts
    4,033
    Kioti DK40SE Hydro
    Pic's....
    Attached Images Attached Images
  10. #10
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,728
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    My septic leach fields was dug with one of those 350s, but yours
    looks MUCH nicer. The crawler with backhoe was the only way to
    dig my 6' deep trenches on a 40% hillside.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
