Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Super Member
    Join Date
    Feb 2006
    Posts
    6,138
    East PA or 750 mi. east of a short man named Dar___
    Kubota, AGCO, New Holland LB
    Default Re: Harbor Freight's little Towable Backhoe
    The 3pt hitch backhoes aren't that bad....back in the late 70's early 80's we had a small farm and we had a kubota 245DT with a 3pt backhoe.
    You wouldn't believe some of the stuff we did with that thing. Way more than what you're proposing. Plus, if you have soft soil, it should be easy digging.
    That Yanmar is just beggin for a hoe.
  2. #12
    Join Date
    May 2005
    Posts
    194
    Deadwood Falls Louisiana
    Jinma JM200LE
    I looked hard at the HF backhoe last year and decided to make a MetKit 708 Cadddigger with high performance cylinders instead. Health issues have delayed construction until cooler weather this fall. I suspect most problems with 3pt backhoes are off axis work at far reach. I will have no time pressure and can move my tractor as needed to keep the hoe force working against the pads. If I break it I all ready bought it and Tommy can sell me some new tractor parts.
    Harold
  3. #13
    Super Star Member California's Avatar
    Join Date
    Jan 2004
    Posts
    10,018
    Sonoma County
    Yanmar YM240, and now just one YM186D
    Quote Originally Posted by Builder
    I may have located a Kubota K-650 backhoe. Is that what you had?
    I started a thread on that subject over in Kubota Buying forum to see if someone can describe that model, since a search here and on Google returns nothing.
  4. #14
    Elite Member
    Parts Supplier
    MessickFarmEqu's Avatar
    Join Date
    Feb 2004
    Posts
    5,410
    Lancaster County, PA
    You should be able to get a Woods BH6000 with a 3pt kit for under $5000. Use it, and then sell it on ebay when your done.
  5. #15
    Member
    Join Date
    Jul 2006
    Posts
    41
    For all the work and applications that you have, I would strongly recommend forgetting the towable unit. It and you will get worn out very fast. Try sticking with eBay for a while for something that you can really use. Do an advanced search for a backhoe within 200 miles with email notification for new items. Last year, I bought a meticulously maintained Case 580CK for $6000. It needed absolutely nothing, came with three sizes rear buckets, all manuals, and a bunch of spare parts. It runs like a charm and the only money put into it over the last year has been fuel, grease and an oil change. Maybe I was just lucky.
  6. #16
    Join Date
    Jan 2004
    Posts
    10,018
    Sonoma County
    Ok, I appreciate everyone's advice. Several of you persuaded me the HF unit is an ineffective toy, and to look for a real backhoe.
    I found one! It's a kubota 3-point backhoe, sized for the model Kubota (L225) that is a near-twin to my Yanmar in size, hp, and age. That's a 4x8 trailer in my photo for a size comparison.
    It's in excellent condition since the original owner was a farmer who only used it occasionally. I don't see any wear at all in the pins.
    The Kubota dealer says these were supplied by a US manufacturer, so I would like to identify the real manufacturer if possible. Does anyone recognise my photos?
    I'll continue posting in this thread for a bit, while I am asking dumb beginner questions then start a new backhoe thread over in the Yanmar forum (my TBN home).
    Thank you to all of you. There is tremendous breadth and depth of expertise here and I appreciate your sharing.
    Attached Images Attached Images
  7. #17
    Banned shvl73's Avatar
    Join Date
    Nov 2003
    Posts
    2,552
    NH
    Mahindra 2810HST
    I think you'll be really glad you went for the real thing. It looks to be in real good shape.
    Enjoy it!
  8. #18
    Super Member
    Join Date
    Feb 2006
    Posts
    6,138
    Quote Originally Posted by California
    You kicked-butt my man! that's an excellent 3pt backhoe you wont be disappointed!
    That backhoe brings back memories....we widened streams, dug-up stumps dug miles of footings, trenches, etc.
    Great job, that will cick the crap out of the HF towable backhoe.
    Anytime you need me to spend more of your money, just let me know
  9. #19
    New Member
    Join Date
    Dec 2007
    Posts
    1
    I purchased a towable"Trencher" from Harbor Freight 2 yrs ago at first it did great I was digging in pretty hard ground at times The unit started to come a part I mean i replaced every cylinder,hoses,main bucket boom "it broke in half", both front support brackets,engine,tires Its not bad if you want to buy 2 the warranty is very bad I first ordered parts from Harbor Freight but was sent a hydralic pump -for a cylinder an engine for a main bucket boom so I will use mine for flowers and roses or so and rent one to dig big holes
  10. #20
    New Member
    Join Date
    Jul 2015
    Posts
    3
    tarheel, north carolina
    massey furguson 1030 4wd
    Quote Originally Posted by OleBill View Post
    i have the harbor freight back hoe. when it works it works good. but the center seal on all the cylinders leak over time. ive had the rod nuts back off several times.broke the cylinder ends off twice. replaced the controle lever pack twice. put two pumps on it. riped the bucket apart twice. for the money i have had alot of fun with it. i have worked it pretty hard. if you can't work on them then leave them alone. if i had to pay to get mine fixed i could have bought a comercial duty one. the bucket just ripped off again so im going to try a dr 9 in bucket. the cylinders.....well i will probablyfind another source for then also since ive had trouble with each and every one.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
