Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    Join Date
    Feb 2008
    Posts
    1,854
    Orstraya , Ex convict stock , G'day .
    Default Re: Which cutter head rotation ?
    Thanks for your help . With no means of changing the direction of oil flow when using hammer piping , what happens when the rotor gets jammed ? Do you just run the rotor backwards on the ground to free it ?
    The funny thing with this Chinese stuff is that 30 minutes after you've had one you feel like another
  2. #32
    Join Date
    Jan 2007
    Posts
    125
    Roxton Falls, QC
    Any, as long as there's a DENIS CIMAF head on it ;)
    If you mean jammed as in intentionally jamming the rotor to test relief pressure setting, then what happen is just that: not able to turn, the motor will go in relief.
    If you mean jammed as in inadvertently jamming the rotor with a piece of wood that get stuck between the back of the drum and the tub, well, to be honest, this is unlikely to happen. If you look at the picture of a rotor, you'll see those rings that limit the size of bites that can be taken. So before a piece chunk of wood can get into the rotor, it will have been chipped in small parts... (Again, fellow competitors, that's part of our patent. Please invent something else. )
    But if that was to happen, if you happen to jam the rotor with a piece of wood, then, you're right, you can shut down the brushcutter and have it "manually" turn backward on the ground to free it.
    Attached Thumbnails Attached Thumbnails Which cutter head rotation ?-denis-cimaf-rotor-close-up
    Frederic Denis
    DENIS CIMAF Inc.
    www.deniscimaf.com
  3. #33
    Join Date
    Feb 2008
    Posts
    1,854
    Yes , being jammed with a piece of wood is what i was meaning . That is a cool looking rotor , i can see now the reason the rings are on it . They would act like the hydraulic infeed rollers on a wood chipper , holding the timber back while the cutters do their thing gradually feeding the timber in and stopping the rotor from becoming bogged down , good thinking .
  4. #34
    Join Date
    Jan 2007
    Posts
    125
    Roxton Falls, QC
    I'll pass your good words to daddy Laurent and uncle Gilles. They are the brains behind this concept.
    Frederic Denis
    DENIS CIMAF Inc.
    www.deniscimaf.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
