EddieWalker
Epic Contributor
Last Saturday I went to the local auction hoping to buy a grapple that they had there. It ended up selling for way more then a new costs, so that was a waste. While wating around for the grapple to come up, I found a Ditch Witch 3500 DD with 1,720 hours on it. The front tires are worn, but the backs look almost new. It had just been painted, so that made me nervous, and it wouldn't start. I went and looked at some other stuff, but wanted to check out the Ditch Witch again. It was gone. I looked around and found where they had moved it. So now I know it starts, I just had to figure out how. It turned out that the safter switches to be in neutral are out of adjustment and you have to get them just right for it to start. When this is right, it fired right up!! There was no smoke and everyhing worked. The chain spun, it went up and down and the blade was able to lift the front end off of the ground and keep it there. I drove it a little and couldn't find anything serioulsly wrong with it.
This wasn't and isn't something that I really need right now. I've seen similar machines sell for $8,000 to $10,000 depending on age and condition. I figured that if I could get it for half of that, I would be a fool not to buy it. At $3,000 it was me and one other bidder. At $4,000 he quit bidding and it was mine.
It has the Duetz Diesel engine, but I don't know how many HP. It's missing a few teeth, but I don't know anything about them or if it needs all of them. I've searched on ebay for a manuel, but so far haven't found one. The engine and filters were painted over, so I'm going to replace them with new ones. I have two small projects for it sometime this year, but other then that, it will just sit for a few years until I'm done with my dirtwork and ready to start installing my underground lines. Then it will be almost non stop!!!
Any thoughts or suggestions?
Thank you,
Eddie
Thank you,
Eddie
