Schultz
I've got a Vermeer grinder that has a Wisconsin 65 hp v4 engine. I've got no spark right now. I had spark until a wire or the ignition switch shorted out. It's a wire that runs from the ignition switch to the carb, it melted through the casing it's entire length, then the ignition coil went up in smoke and popped it's case. After replacing the ignition key switch and the coil I no longer have spark.
Does anyone have any advice?
Does anyone have an electrical schematic of the starting system?
What does the wire to the carburetor do?
Should I see 12v at the ignition coil, or does the magneto (if it has one) just pulse it when it should spark.
