Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2008
    Posts
    173
    Shaftsbury VT
    Kioti DK 40s
    Default Thoughts on USED Yanmar Mini
    hey folks,
    Thinking of buying a mini to use around the house. I need to install some french drains, reditch old ditches, and pick some stones from the field and carry to the hedgerow. I will also be installing some small culverts in logging roads and transplanting about 50 6' pines for landscape purposes. It is the equivalent of a Yanmar YB301, it has a new hour meter so exact hours are unkown but assumed to be "a lot". Here are some pictures
    Attached Thumbnails Attached Thumbnails Thoughts on USED Yanmar Mini-ex1-jpg   Thoughts on USED Yanmar Mini-ex2-jpg   Thoughts on USED Yanmar Mini-ex5-jpg   Thoughts on USED Yanmar Mini-ex6-jpg
  2. #2
    Join Date
    Jan 2008
    Posts
    173
    Shaftsbury VT
    Kioti DK 40s
    Default Re: Thoughts on USED Yanmar Mini
    cough?
  3. #3
    Join Date
    Oct 2008
    Posts
    132
    Florida
    Dont know anything about Yanmar Mini's, but a friend had a Yanmar tractor years ago and raved about it.
    I recently purchased a JD mini, and dont regret it for a minute... Fun to drive and very usefull.
  4. #4
    Super Member
    Join Date
    Aug 2004
    Posts
    6,489
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Looked at the closeup of the sprocket--
    That machine is well worn and will want to shed the tracks.
    Check the chain roller bushings and you'll probably find that they are very oval shaped matching the worn sprockets.
    Pads look fair suggesting that the machine did not see much stone work but sprocket deffinately show mileage.
    I have operated that model and it works nicely but track/sprocket is pricy.
    Might still be a good buy (depending on price), but be prepared to loose a track from time to time.
    You would need to avoid sharp pivoting turns and know how to get the tracks back on should you drop one.
  5. #5
    Veteran Member Kays Supply's Avatar
    Join Date
    Jul 2006
    Posts
    1,119
    Southern Illinois
    Iseki TA 207
    Just as a reference, I sold my Yanmar B-22 4-5 years ago for $10,000. It had good or better sprockets, good rubber tracks, new pins and bushings and a fresh paint job. Less than 1200 hrs. It was several years newer model.
    Attached Thumbnails Attached Thumbnails Thoughts on USED Yanmar Mini-b-22-2-jpg
  6. #6
    New Member
    Join Date
    May 2009
    Posts
    1
    I heard they are good I'm looking at buying a yb301 but having a hard time finding parts was wondering what the john deare model and serial #s are on the one you are thinking of buying and if parts are available. thankyou the one I am looking at is a gray market which means not for us market and no parts listings available
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
