OP
futuresweets10
- Joined
- Jun 6, 2010
- Messages
- 125
Futuresweets10, of course with anything weight vs. fulcrum, But if you have braced good for amount of weight I would think it should work. Far as weight, a careful experiment would need to come in play. With that extra extension out there you could bend bucket cylinders. Dfkrug probably can give you good examples of that.
I do likeDfkrug's idea. Dfkrug has alot of nice builds you should check out.
Alanb has a nice setup there also.
Youve got me scared now.... After all ive been through with the FEL on my hoe the last thing I need is to bend a cylinder. Ive been thinking about it though and im wondering how the cylinder can get bent. My machine has work port relief valves. Isn't the point of these to allow the pressure to leak down if too much force or weight is put on the cylinder? Would this prevent me from being able to bend a cylinder or at least make using my FEL for this a bit safer?
