haven trouble getting into gear set for 15 years clutch is not stuck
When I started working for Cat back in the day, seems that was what most of the work I did consisted of - making the old iron run again. But never ran across anything like you guys. Far back as I went, as I recall was mid-fifties. It's all kinda blurry...My 1943 D7 has grease fittings on the clutch plate along the shaft. Even if the clutch is not stuck it might not be sliding freely on it's shaft. It also has a clutch brake that stops gear movement. Ask also on https://www.acmoc.org/.
Bob, Old Cats have been submerged for longer than 15 years & been sucessfully resurrected, no need to part out. MikeD74T
.....Since your machine is so old, I would think you should buy a newer used one. The parts are hard to find and expensive. Plus you don't know how serious the problem is. Its a big gamble.
