Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Join Date
    Jun 2004
    Posts
    2,409
    USA
    Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
    Default
    I'd buy a BobCat T250 or T300. Awesome machines and plenty of weight. I'm not a fan of wheeled skid steers. Too bouncy! Lol!
    Like overs have said you can attach nearly anything to the bobcat. Plus BobCat brand uses kubota Diesels!
    Good luck!
  2. #12
    Super Star Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    10,276
    Texas - from the brush and pear to the piney woods
    John Deere 110 TLB
    Default Re: My farm construction business is growing, recommendations on equipment?
    Quote Originally Posted by Verticaltrx View Post
    So it sounds like a skid steer would be an ideal machine. Just need to decide on the type and size. I've spent many hours running 753 and 763 bobcats and they seem to be pretty capable as far as the dirt work goes. What I'm not sure of is if that size machine would be good for handling my post driver (1100lb), and setting trusses?
    I can get a new S150 (comparable to old 763) for under $25K. I don't know a whole lot about other brands of skid steers, but I'm open to suggestions.
    Congratulations to you on the business development!
    Lots of good input here. Keep us updated on your success.
    Are you around Washington co. by chance?
  3. #13
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    Quote Originally Posted by Duffster View Post
    I would a little bigger. Like the 175 or 185 size.
    Based on what tasks? As far as I know the S150 and 175 are the same machine just with different boom setups. Operating weight is within a couple hundred pounds, lift capacity is a bit more on the vertical lift path machines. The only vertical lift skid steer I've ever run was a very old New Holland L425, so that isn't much of a comparison. Maybe I don't know what I'd missing out on having never really used a vertical lift machine?
    Quote Originally Posted by PapaPerk View Post
    Good luck!
    I'm going to stick with a wheel machine, most of my use won't require tracks, and what does it sounds like over the tire tracks would be great. If money were no object then I might go for one of those machines, but unfortunately it still is, lol.
    Quote Originally Posted by two_bit_score View Post
    Thanks. I'm actually in the New River Valley area, Montgomery, Pulaski and Floyd counties.
    Hopefully the success will continue. My overhead is very low so one big job would generate enough profit to buy a new machine. Keeping my fingers crossed.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  4. #14
    Elite Member Duffster's Avatar
    Join Date
    Mar 2009
    Posts
    4,372
    Wisconsin
    Everything.
    A 175 has almost 1000 lbs more tipping load than a 150. That is the number that counts when you are going to use it as a crane.
    A vertical lift machine really shines when lifting and using the boom pole. I wouldn't own another radial lift machine.
    "If everyone is thinking alike, someone isn't thinking." George Patton
  5. #15
    Join Date
    Jun 2004
    Posts
    2,409
    USA
    Default
    The tracked machines just do a great job of leveling, etc. Plus they ride way smoother. But I understand about the budget.
    With that being said I would want the large frame Bobcat and not the medium frame... Especially when using a boom pole! Skidsteers are already notoriously tippy! Good luck!
  6. #16
    Join Date
    Apr 2009
    Posts
    231
    Waxhaw, NC
    Bobcat A300, Kubota F3680, JCB 212S sold
    I build barns, fences do grading and all kinds of other stuff. I purchased a Bobcat A300 in 2004. And have been happy with it. Nice to be able to steer the wheels when running through pastures without tearing the grass up. I also purchased a hydraulic boom for it from Sheyenne Manuf. I believe and have also been pleased.
    I have a JCB 212 backhoe that I use to dig footers and do some clearing. Its a nice little machine but a bit heavy and gets used more around the house. Wish someone would come along and want to buy it.
  7. #17
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Good to hear from others in my business. The AWS units look nice but I bet they are spendy.
    In the coming months I'm going to rent a few different models and test their capabilities. I don't have any more big barn projects coming up until next spring, but I can hang a few hundred pounds of tractor weights off the jib crane to see how they perform. The ability to set trusses is my main concern with any skid steer, I think all the other tasks could be easily handled by most. I'll definitely take a look at the S175, also see how the additional counter-weight kits affect ROC on the S150.
    Thanks for everyone's input, as I posted in the first post I'm also getting ready to buy a trailer. Based on the skid steer recommendations I think I'll go with an 18', 6-ton equipment trailer. Should be heavy duty enough to haul most skid steers plus an attachment or two, also long enough for my tractor and bush hog.
    Any more input is also welcome, I'll try to update this thread as things progress.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    JD 265
  8. #18
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,381
    NW Oregon
    Deere 317 & L118
    I have done very similar tasks with all sorts of machinery and a Skid steer is definitely the ticket to the right machine. That being said, lift capacity is a huge part of it all. The S175 lifts around 1700 lbs. which in reality isn't very much. When my step mom was in teh market for a used skid steer, lift capacity was the on top of the list. In research, we found that John Deere offers the best lift capacity in the CTL division over most every other brand. So in turn she got a CT322. Here are some listed on Machinery trader for a good price.
    DEERE CT322, Used DEERE CT322, DEERE CT322 For Sale At MachineryTrader.com - Page 1
    The CT322 lifts close to 2 ton, I have maxed it out before at that. The tractive effort is incredible. On Monday I used it on a job to clean out an arena that was buried from 1'-2' in manure. This was a build up over many years and it was very packed down. So I started off, the CT322 weights in at around 4 ton which provides incredible tractive effort and makes it almost unstoppable. i pushed through the spots that were 1' deep like it wasnt even there, i pushed some 50' before taking a scoop, it did not stop. The tracks also offer a smooth ride and make it very effective at grading uneven terrain. It has plenty of hydraulic GPM to power your post tamper as well as run a PA30 PHD in hard clay. The arena job took me 5 hours, I also scraped out an aisle way as well. IMO Deere also has the best roll back on their buckets, you can hold bigger loads without loosing them on the way. The visibility all around is great, i love the lower back window, it makes backing into places a lot easier. The 66hp engine is actually very quiet, the more throttle it gets, the quieter it gets. I know i am sounding like a sales man trying to sell you on the CT322, but this is just out of my great experience with one. It will out do an S150 as well as a S175, even a T190. Try one out and see what you think about it.
    Attached Thumbnails Attached Thumbnails My farm construction business is growing, recommendations on equipment?-img_0130-jpg   My farm construction business is growing, recommendations on equipment?-img_0132-jpg   My farm construction business is growing, recommendations on equipment?-img_0140-jpg   My farm construction business is growing, recommendations on equipment?-img_0143-jpg
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, Bobcat landplane ,4 in 1 bucket, Pallet forks
    2005 John Deere L118
    42" deck, bagger
  9. #19
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Just when I think I have this figured out....
    So I was at the kubota dealer this morning getting some parts and they had a new MX4700, 4wd, HST, R4 tires, LA844 loader, there that looked like a pretty useful little machine. Loader specs are similar to the size skid steers I'm looking at, although the hyd. flow is less. Fully ballasted with R4 tires it would weigh about 6500lbs, has a 72" bucket, lifts 2400lbs to 111"
    Anyways, just for the sake of discussion how would one of these work out for my operation? I think for most of the tasks it would be as good, maybe better at some, than a skid steer. More stable on the steep hills, easy to use my post driver with, plenty of stability/size to use the jib crane, etc. I think it'd probably run a skid steer type hydraulic auger decently enough for the limited amount I'd be using it, most sheds I build require anywhere from 6 to 24 holes.
    Where I'm least sure about this setup would be for site prep and leveling building pads. The cost of the tractor is about $2K less than the skid steer which would buy a nice commercial duty 7' box blade. How efficiently would this combo be at moving soil in a cut/fill situation making a level building pad? I know the loader wouldn't dig nearly as well as the skid steer, but a box blade that size you're moving about 3/4yd per pass. Thoughts?
    Just trying to weigh out every available option here
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    JD 265
  10. #20
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,004
    Lakes Region, Maine
    M 9540 Kubota
    Just say no. A tractor fel is just not built for digging, it's for chores and loading, a big difference. It looks like 95% of your respondants vote for the SS, I do too. I have had a bunch of 'em and have worked my way up to the biggest one made. 110 hp and 10,000 lbs and just shy of 12' lift with a 55" wheelbase. (Gehl 7800) Bobcat now makes a machine that looks like a real challenger in that class SS but they are to new to find any used ones. The Gehl's 7800/7600 have been around for long enough that they are not hard to find used. Don't be afraid of used, I traded my Deere 260 SS on the Gehl used at 600 hrs or so, now at 1500 and no prob. I do all the same things that you said that you will require of your machine and IMO it's the best all round tool for those jobs.
    The drawback of this machine is that is not the same as your std. SS, It wont fit between the fenders of a trlr. (with the spacers for OTT tracks) and like I said, it's 5ton weight kinda puts you into a deck over trlr @ 14.000 gvw min. I built a 93" wide tooth bucket for it (1" wider than the SS) and it will fill it every time for your dirt work jobs. I also built a jib pole (stealing ideas from the Sheyann unit) and set trusses with it and it also makes a great rope swing over the pond! Good luck
Similar Threads
  1. Falls Farm & Garden Equipment Spring Auction
    By rancar in forum Buying/Pricing/Comparisons
    Last Post: 04-07-2012, 01:31 PM
  2. Starting a hobby farm. Questions Questions!
    By PapaPerk in forum Projects
    Last Post: 03-05-2011, 02:09 PM
  3. iowa farm equipment company.
    By bill in ny in forum Ag Tractors & Machinery
    Last Post: 03-11-2010, 11:09 PM
  4. How much tax on tractors & other farm equipment?
    By TBone in forum Related Topics
    Last Post: 06-14-2001, 09:03 AM
  5. Welcome to 'Construction Equipment'
    By Muhammad in forum Construction Equipment
    Last Post: 04-06-2000, 04:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
