Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Silver Member Kioti guy's Avatar
    Join Date
    May 2011
    Posts
    191
    Severn Bridge Ontario
    2011 kioti ck 20S Hst,Case D
    Default
    It looks like my old john deere crawler loader . Mine was a jd 1010 but it was 4cyl diesel. That pic looks like a late 50s early 60s jd 430 c. Just a guess but they had two cyl gas john deere motors. .......Craig
    2011 Kioti Ck 20s Hst,60" BB,Buhler Snow Blower
  2. #12
    Silver Member DrRick's Avatar
    Join Date
    Mar 2006
    Posts
    197
    san angelo, texas
    dk55, jd 450,case 811b,kioti mechron,farmal cub & super c
    Default Re: What type of Dozer is this?
    it is definately a john deere 440 ICD with a John deere 831 loader on it. Looks like they have taken off the rear weights and added a homemade rops. It has dry clutches and may not steer if it has sat for a while. I had one with the detroit 2 cylinder in it. probably a '59 or '60 model. rick
  3. #13
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    Well first of all technically it's not a dozer, it's a track loader- see the relatively flat grousers and other obvious appendages.
    I'll bet it's a Deere, maybe late '50's because there are striking similarities to the one here.
    John Deere Bulldozer
  4. #14
    Elite Member JasG's Avatar
    Join Date
    Jan 2004
    Posts
    3,207
    CNY
    Kubota L3240
    I would agree that it is a Deere 440. Here is one with a DD engine.
    John Deere 440 Crawler Loader 2 cyl detroit diesel - YouTube
  5. #15
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    I could have sworn the OP said it had a GAS engine in it.
    Here is the specs on the JD 1010 (wheel & crawler).
    http://www.johnnypopper.com/weirddeere/NG/The_1010.html
    Also, here is a JD1010
    http://www.tractorbynet.com/forums/j...bulldozer.html
  6. #16
    Platinum Member HHR's Avatar
    Join Date
    Oct 2010
    Posts
    692
    Northern MN
    1997 Daewoo Dsl 801
    Default
    I just got confirmation by the owner that it is indeed a late fifties JD 440. Thanks for all the input.
  7. #17
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    Well, the sky didn't fall after all. Good news.
  8. #18
    Join Date
    Oct 2010
    Posts
    692
    Northern MN
    1997 Daewoo Dsl 801
    Default
    It turns out that the plugs were fouled. I put in a couple of new ones in and she fired right up.
    Attached Thumbnails Attached Thumbnails What type of Dozer is this?-image-3763444128-jpg   What type of Dozer is this?-image-3761554774-jpg
  9. #19
    New Member
    Join Date
    Oct 2011
    Posts
    1
    3...2010 deeres 580c case 480c case 610 adams grader
    i own 3 2010 deeres its not 2010 not 1010 looks like 440
  10. #20
    Join Date
    Oct 2010
    Posts
    692
    Northern MN
    1997 Daewoo Dsl 801
    Default
    Here is a photo to clarify that it is a JD 440.
    Attached Thumbnails Attached Thumbnails What type of Dozer is this?-image-1157179690-png
Similar Threads
  1. What to look for when buying a dozer
    By Flatheadyoungin in forum Construction Equipment
    Last Post: 01-20-2009, 10:37 PM
  2. Help choosing the right dozer.
    By Jeff244 in forum Construction Equipment
    Last Post: 06-05-2008, 09:24 AM
  3. What do you figure a Nortrac/Yuchai 30HP Dozer can do better than a BX24?
    By montelatici in forum Kubota Owning/Operating
    Last Post: 04-16-2007, 09:48 PM
  4. Rotary Cutter Rotary cutter: pull type vs hitch
    By N80 in forum Attachments
    Last Post: 08-11-2005, 02:57 PM
  5. what type of hay tedder?
    By barticus73 in forum Attachments
    Last Post: 04-21-2004, 10:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
