Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Silver Member Jnasystems's Avatar
    Join Date
    Nov 2010
    Posts
    125
    Waukesha Co, WI
    1986 Ford/NH 1520, 1950 Allis Chalmers WD, 2001 NH EC35 (track hoe)
    Default
    Well, I built the model - I think it will work well. I did learn that all 3 of my buckets are slightly different sizes though. Luckily the one I started with had the pins the closest together, so the others should fit, just a little looser. I didn't make the pin sleeves yet and those will go into the model before I start assembling the real deal to make sure nothing binds, but I feel like things are coming together.
    Attached Thumbnails Attached Thumbnails Mini Ex Quick Attach Build-image-659189847-png   Mini Ex Quick Attach Build-image-2819197741-png   Mini Ex Quick Attach Build-image-3343857331-png
  2. #12
    Join Date
    Nov 2010
    Posts
    125
    Waukesha Co, WI
    Default
    Got a bunch done today. Machined the top set of sleeves and got the bottom 2 cut to 1/8" over. Now I have a problem - I don't know how to hold the bottom sleeves to bore them to the right diameter. I put them in the chuck, but they wobbled too much for me to feel comfortable cutting on them. Any suggestions? Here is the latest pic.
    Attached Thumbnails Attached Thumbnails Mini Ex Quick Attach Build-image-3759227379-png
  3. #13
    Member
    Join Date
    Jan 2008
    Posts
    33
    NorTrac NT254 (Jinma)
    Default
    aczlan, Thanks for the great answers. Makes perfect sense now, why didn't I think of that :^)
    Quote Originally Posted by Jnasystems
    I don't understand what you are asking? Perhaps a photo of how you tried to chuck it, so we can figure why it would wobble. A piece of round stock should just go directly into the chuck and then use a boring bar, twist drill, or reamer.
    Gene :^)
  4. #14
    Platinum Member tonyoz's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Queensland & Far South Coast NSW Australia
    Rayco
    Default Re: Mini Ex Quick Attach Build
    In Sydney Australia 2 weeks ago a full bucket detached from an excavator quick hitch killing a truck driver standing beside his rig. The excavator operator failed to insert the safety pin and is now in deep poo. Any quick hitch, manual or hydraulic with a latch tounge can release without a safety pin.
    CTC Mulching
    I'm going to die without any enemies' in the world cause I will outlive the barstards
  5. #15
    Bronze Member hazmat ranger's Avatar
    Join Date
    Jul 2011
    Posts
    54
    Duvall, WA
    2009 New Holland 1510
    Default
    Others have talked about Drawn On Mandrel tubing (DOM) for bushings. I've looked at online suppliers and they have various wall thicknesses and varying ID tolerances.
    Have a few projects myself and think this is a better option than turning my own bushings.
  6. #16
    Silver Member ManAtArms's Avatar
    Join Date
    May 2009
    Posts
    217
    NJ
    2009 Kubota M59
    Can you tack weld them to a jig temporarily for machining and then just grind off the welds when done?
    Quote Originally Posted by Jnasystems View Post
    2009 Kubota M59, Hydraulic Thumb, front aux hydraulics,
    8' Ford 917 Flail Mower
    Belltec H-300 auger, Markham Grapple, Bradco forks
    Landpride GS-1560 Grading Scraper
    2008 ASV PT50
    Other Toys
    Built-Rite 24 HPWS-D splitter
    Dolmar PS-5100s
    Stihl MS-441
    Makita DCS-6401..upgraded to 79cc
    a pit bull or two (RIP Tugboat)
  7. #17
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    I have a quick hitch on my TLB backhoe bucket (photo). While I've noticed no degradation in strength, it does extend the length of the bucket so that it now hits the bottom of the boom if I'm not careful. Most of the damage to the boom was done by the previous owner. I try to curl the bucket and bring in the dipper slowly until it makes contact with the boom. My quick hitch is a bit loose and and does add some slopiness to the bucket. If your bushings are nice and tight, that might not be a problem.
    Attached Thumbnails Attached Thumbnails Mini Ex Quick Attach Build-quickhitch-jpg
    Jim
  8. #18
    Join Date
    Nov 2010
    Posts
    125
    Waukesha Co, WI
    Default
    Quote Originally Posted by ManAtArms
    That's a great idea, but I will have to file it away for next time as I found a machine shop that was willing to machine them for a case of beer.
    Not much else has been done since as other projects got in the way. Maybe I will have some time this weekend to finish drilling the 3" holes in the .5" plate. Those take for ever with a hole saw, maybe I should crank up the drill speed some. I dread the 1" piece that I need to drill.
  9. #19
    Join Date
    Nov 2010
    Posts
    125
    Waukesha Co, WI
    Default
    Well, I finally got all the parts cut out. Now the grinding begins. I will have a bunch to do since they were cut freehand for the most part.
    Attached Thumbnails Attached Thumbnails Mini Ex Quick Attach Build-image-39748476-jpg
  10. #20
    Join Date
    Jul 2005
    Posts
    1,302
    lower part of Md.
    JD310, ASV RC-100
    Wow, wish my freehand cutting was that good! Is this modeled after the JD or Cat in your picture?
Similar Threads
  1. quick attach forks for Kubota 3130
    By gfilion in forum Build-It Yourself
    Last Post: 10-31-2011, 03:49 PM
  2. Tractor side SS quick attach build L3400
    By mwb in forum Build-It Yourself
    Last Post: 08-04-2009, 01:06 PM
  3. Are loader quick attach plates pinned on?
    By Zoombah in forum Attachments
    Last Post: 12-13-2006, 06:02 PM
  4. To quick attach or not quick attach.
    By smittyd3 in forum Kubota Owning/Operating
    Last Post: 01-04-2005, 07:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
