Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Member obb's Avatar
    Join Date
    Dec 2012
    Posts
    32
    Sahuarita az
    internal exstingaho back hole 3500 A siar
    Default Re: caterpillar 933f question
    Looking for the Chilton on the 933f 1962 Caterpillar and won't move any further yes I checked with Caterpillar a little too proud of the book for me at $600 the book seems a little out of reach .. Pulling the motor out and it's hung up on something I have pulled all the bolts that I can find pulled the cover off of the bell housing and found four more bolts pulled them and the motor moved about a half-inch not sure at this point what to do thank you
  2. #12
    Gold Member Winmac's Avatar
    Join Date
    Dec 2011
    Posts
    367
    Landini 6860
    Default
    caterpillar 933f question-image-1407847538-jpg
  3. #13
    Member obb's Avatar
    Join Date
    Dec 2012
    Posts
    32
    Sahuarita az
    Quote Originally Posted by Winmac View Post
    cool book does it have anything on removing the motor from the transmission it looks like the motor in radiator all come out together after removing the PTO on the front of the radiator thanks obb
  4. #14
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,843
    Earth
    A yellow one
    Did you try here for manuals?
    Official Caterpillar Service Manuals, Owners Manuals (OMM), and Parts Books for Engine & Construction Equipment Repair
    If you go to the Cat schools they will give you a ton of manuals. For free.
  5. #15
    Member obb's Avatar
    Join Date
    Dec 2012
    Posts
    32
    Sahuarita az
    Thank you I will check into this.. just got the tractor two months ago. The number one piston main bearing is spun so I decided to pull the motor to redo the crake and it's not like a Chevy 350 or even a ford 351 ha ha thank you ..obb
  6. #16
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,843
    Earth
    A yellow one
    Quote Originally Posted by obb View Post
    If it spun a bearing then you have a lot on your plate. Sorry to hear that.
  7. #17
    Member obb's Avatar
    Join Date
    Dec 2012
    Posts
    32
    Sahuarita az
    Thank you just check that site out that you gave me and the service manual is in but had $600 at that price I'll play it by I...... I think there is a fork in the transmission that I need to pull at this point....... it's not so bad it's the first tractor of work on used cars and trucks this is just a little bit bigger but pretty much the same thank you obb
  8. #18
    Join Date
    Dec 2011
    Posts
    367
    Landini 6860
    Default
    The books i have are only for operator / basic maintenance and are for a G model, i believe the engine, clutch and transmission are different than yours.
    I dont want to discourage you but have you looked into parts availability for the engine? I had a difficult time finding stuff for mine and the local cat dealer has been of no help either.
  9. #19
    Member obb's Avatar
    Join Date
    Dec 2012
    Posts
    32
    Sahuarita az
    Yes the cat dealer here has the gasket set and the main bearings but that's pretty much it I have a buddy with the machine shop he said he could fix the connecting rod and redo the main crank I'm hoping that's all I'll need if not I can part it out for what I have into it thank you obb
  10. #20
    New Member
    Join Date
    Oct 2012
    Posts
    7
    linn,mo
    caterpillar 933f
    hi, thanks for feedback on 2 grease fittings. have a good day
Similar Threads
  1. Need tooth adapter 4K1690 for Caterpillar 933F
    By dweitzel in forum Construction Equipment
    Last Post: 11-01-2012, 12:00 AM
  2. Caterpillar D5N Dozer Rental Question
    By davemhughes in forum Construction Equipment
    Last Post: 03-04-2007, 07:36 PM
  3. Caterpillar engines
    By linpat in forum Buying/Pricing/Comparisons
    Last Post: 01-18-2006, 10:40 PM
  4. Caterpillar/Iseki???
    By welder691 in forum Iseki
    Last Post: 06-30-2005, 04:40 PM
  5. Caterpillar Tractor
    By Thomas in forum Photos
    Last Post: 09-29-2002, 02:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
