Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    New Member
    Join Date
    Oct 2012
    Posts
    7
    linn,mo
    caterpillar 933f
    Default caterpillar 933f question
    i just bought a 1964 caterpillar 933f. it has 2 grease fittings by the engine oil dip stick. one has copper line going to front of engine and the other copper line goes to rear of engine. what do they go to and how much grease do you put in??THANKS
  2. #2
    Veteran Member Bob Rooks's Avatar
    Join Date
    Feb 2007
    Posts
    1,801
    Bothell & Silverdale, WA
    '06 Yuchai YCT306-5A Bulldozer
    Default Re: caterpillar 933f question
    If you trace them out, where do they attach on the other end? I'm thinking maybe the equalizer trunnions. This is something that someone has added.
    '06 Yuchai dozer, '00 Mustang 2040 skid steer, Litw BH7600 BH, Trimble equipped 7' Dual Dozer, and other sundry pull toys.
  3. #3
    New Member
    Join Date
    Oct 2012
    Posts
    7
    linn,mo
    caterpillar 933f
    it was ran without the engine cover so the steel housing covering the oil pan is stacked full of old dirt so i can not get to ends. i have been trying to dig compacted dirt gravel oil out of the small holes on sides. the thick steel plate protecting the oil pan must weigh a ton so i have not dared to unbolt that to add to my problems. thanks for reply.
  4. #4
    New Member
    Join Date
    Oct 2012
    Posts
    7
    linn,mo
    caterpillar 933f
    on rereading your reply. this is for sure all original with steel bracket that holds the 2 grease joints that came from the caterpillar factory. this is not a add on. thanks
  5. #5
    Join Date
    Feb 2007
    Posts
    1,801
    I used to use a heavy duty transmission jack to remove belly pans. How about a picture of those two zerk fittings? Someone else that has a 933, 955, or 977 may know. I believe if they were Cat OEM they would be steel lines, not copper. I was a field mechanic for the NW Cat dealer, and I can't think of anywhere they used copper tubing. Just sayin'.
  6. #6
    New Member
    Join Date
    Oct 2012
    Posts
    7
    linn,mo
    caterpillar 933f
    it probably is steel tube.the square bracket hoding the grease fittings is attached to the engine. i made some tools to clean most of dirt out and made a cover for engine so it does not happen again.still unable to find ends of tubing. i just thought a 933f owner might reply. thanks-have a good day.
  7. #7
    Join Date
    Feb 2007
    Posts
    1,801
    Other than another owner chiming in, the best solution would be to refer to your parts book and/or owner's manuals. If you don't have them, contact your local Cat dealer, or there are lots of them available on Ebay. Just Google Cat 933F.
  8. #8
    New Member
    Join Date
    May 2008
    Posts
    4
    They are NOT add on's. They are factory. One is for the rear engine trunnion. The other is (I believe) for the hyd pump drive shaft at the front of the engine. A few shots with a grease gun should be sufficient. Steve. P & D Mechanical Heavy Equipment Parts, Repair, and Service - Upstate & Central NY
  9. #9
    New Member
    Join Date
    Oct 2012
    Posts
    7
    linn,mo
    caterpillar 933f
    hi, thanks for the reply. have a good day.
  10. #10
    obb
    obb is offline
    New Member obb's Avatar
    Join Date
    Dec 2012
    Posts
    20
    az
    caterpillar loder 933f 1962
    Hi new to the form jus thought idea gives some insight I have the 933 f 1962 the greasy Certs that you're talking about one goes to the front it hooks to the PTO the other one that goes to the back it hooks to the motor mounts at the transmission and the amount of grease to three pumps or so hope this was helpful thank you obb
Similar Threads
  1. Need tooth adapter 4K1690 for Caterpillar 933F
    By dweitzel in forum Construction Equipment
    Last Post: 10-31-2012, 11:00 PM
  2. Caterpillar D5N Dozer Rental Question
    By davemhughes in forum Construction Equipment
    Last Post: 03-04-2007, 06:36 PM
  3. Caterpillar engines
    By linpat in forum Buying/Pricing/Comparisons
    Last Post: 01-18-2006, 09:40 PM
  4. Caterpillar/Iseki???
    By welder691 in forum Iseki
    Last Post: 06-30-2005, 03:40 PM
  5. Caterpillar Tractor
    By Thomas in forum Photos
    Last Post: 09-29-2002, 01:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
