Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Join Date
    Feb 2002
    Posts
    642
    Connecticut
    BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Kubota 161-3
    Default Re: What size roller for gravel driveways/parking lots?
    I had a similar situation as you, I was looking for a used vibratory roller and they were either whipped or very expensive. I also was not to excited abut having one more engine/piece of equipment to maintain. If you have a skid steer that you use for grading, try looking for a used vibratory roller attachment, I picked one up off of Craigs list and have been very impressed, plus if you need to travel to a job you only need to transport one machine instead of two, just my 2cents. Best of luck with your hunting
    If it has anything to do with diesel, dirt, and shiny things, I'm interested....
  2. #12
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,372
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by Foxtrot08 View Post
    Looking to get a used roller to help maintain our long gravel driveway (1/2 mile) and parking lots at work for our semi-trucks.
    What size should I be looking at? I found a Ingersoll-Rand DD22 about an hour from me, in my price range with low hours on it. It's a 2-4 ton machine with vibration. Plus, still easily transportable at a 3 ton weight.
    Is this enough, or should I be looking bigger?
    Here's the roller my contractor used to install my gravel driveway (20 ft W x 330 ft L, 6" thick crusher run, three 2" lifts, water and roll each lift) and the asphalt paving to connect it to the county road.
    What size roller for gravel driveways/parking lots?-roller-vibrating-jpg
    Good luck
Similar Threads
  1. Grading Gravel Driveways
    By wen in forum Attachments
    Last Post: 07-22-2013, 01:16 AM
  2. Gravel Driveways
    By Conservation in forum Projects
    Last Post: 02-12-2009, 10:20 AM
  3. Gravel Driveways
    By jbrumberg in forum Projects
    Last Post: 03-12-2006, 09:40 AM
  4. Making Gravel Driveways Last
    By JCS_in_KY in forum Projects
    Last Post: 12-22-2005, 09:13 AM
  5. Gravel Driveways
    By buckeye in forum Rural Living
    Last Post: 11-11-2001, 05:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
