Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1
    Member
    Join Date
    Aug 2011
    Posts
    25
    Connecticut
    1986 Ford 1710, JD 410C, and JD 450
    Default John Deere 410C QUESTIONS!!!
    Hello All,
    A couple weeks ago I found a deal I couldn't pass up on a 88' Deere 410C. Machine runs mint and had a new factory engine installed about 1000 hours ago. Hydraulic pump was also replaced within the last 1500 hours. So, there is the good, now the bad. Machine has been neglected and not used for a few years, doesn't look like it was greased very often, and pins/bushings in the hoe are SHOT. It is very loosey goosey and has a crack at the top of the dipper stick. The crack should be easy enough to weld up, and looks like stress from the bucket cylinder was the culprit there. The biggest problem however is the bushings/pins attaching the swing tower to the frame. The bushings are so bad, that there is nothing left and it's riding directly on the frame. Any thoughts? Advice?
    Background:
    My wife and I just bought 20 acres and are going to be building in the spring. This was bought to assist in sitework and the whole construction process as a way to offset costs. After building is done, I plan on keeping it around as a homeowner machine to work on various projects and clear snow (650ft driveway). Everything on the machine is in decent shape, and it runs great. It is typically a 12-15k machine and I paid 5K for it, so i don't think I can get hurt on it.
    Does anybody own one of these machines that can tell me their experiences with them? There doesn't seem to be much info out there, and parts seem a bit difficult to source. Also, if anybody owns one, could somebody take some detailed pictures of the swing tower to frame connections so I can compare since mine is a mess.
    Thanks In Advance
  2. #2
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default
    The parts should be readily available through Deere.
  3. #3
    Member
    Join Date
    Aug 2011
    Posts
    25
    Connecticut
    Default Re: John Deere 410C QUESTIONS!!!
    I was more referring to the aftermarket parts world.. factory parts are just so damned expensive
  4. #4
    Platinum Member pjbci's Avatar
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    JD 4840, 450j, 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
    Default
    Try heavyquip.com for aftermarket parts.
  5. #5
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Default
    Quote Originally Posted by Nicetoy
    Ok I misunderstood what you were gettin at. I agree that Heavyquip would be a great place for after aftermarket parts.
    Are the pins and bushings in your boom the parts that are worn out?
  6. #6
    Member
    Join Date
    Aug 2011
    Posts
    25
    Connecticut
    yes, the loader is pretty worn too, but usable as is... The worst is the frame to swing tower pins/bushings
  7. #7
    Join Date
    Jul 2005
    Posts
    1,302
    lower part of Md.
    JD310, ASV RC-100
    Probably a great choice for your adventure.
    Heavyquip should be able to help out. Don't forget though, other places make stuff like pins and bushings Pins and Bushings Online Catalog at Ring Precision Component Parts
    get yourself the books from JD too, if you download it, the prices aren't horrible. https://www.johndeeretechinfo.com/
  8. #8
    Member
    Join Date
    Aug 2011
    Posts
    25
    Connecticut
    UPDATE!!!! With Pics! Here is the Frame to upper swing tower mount after I got it all apart. Talk about ugly!John Deere 410C QUESTIONS!!!-old-frame-mount-jpg
  9. #9
    Member
    Join Date
    Aug 2011
    Posts
    25
    Connecticut
    Default Re: John Deere 410C QUESTIONS!!! * Updated w/ Pics
    The frame was so bad, I didn't have many options. I found a Parts machine, and bought the Swing Tower/ Boom/ and Dipper from it. The guy also cut off that upper Frame to Swing mount for me, and I had to call in my mobile Fab guy!. Shown is the old mount/swing, and new ones.
    John Deere 410C QUESTIONS!!!-swing3-jpg
    John Deere 410C QUESTIONS!!!-swing4-jpg
  10. #10
    Member
    Join Date
    Aug 2011
    Posts
    25
    Connecticut
    New Frame mount welded on with new bushings.
    John Deere 410C QUESTIONS!!!-new-frame-mount-jpg
    John Deere 410C QUESTIONS!!!-new-frame1-jpg
    John Deere 410C QUESTIONS!!!-new-frame2-jpg
Similar Threads
  1. John Deere 445 questions
    By zimnick in forum John Deere Lawn & Garden
    Last Post: 08-31-2012, 08:55 PM
  2. John Deere LA115 questions
    By leonz in forum John Deere Lawn & Garden
    Last Post: 12-22-2011, 12:46 AM
  3. How much vehicle to tow Deere 410C Backhoe
    By Jaspell in forum Trailers & Transportation
    Last Post: 04-07-2011, 12:02 AM
  4. Buying Advice John Deere, and some questions
    By stlawrence in forum Buying/Pricing/Comparisons
    Last Post: 10-29-2010, 03:56 PM
  5. John Deere 870 questions
    By Mrwurm in forum Buying/Pricing/Comparisons
    Last Post: 02-27-2002, 08:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
