Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    Default Re: Subaru Brand Generators
    Quote Originally Posted by TimberXX View Post
    Whats the advantage of aluminium vs copper?
    There is no advantage of aluminum over copper electrically, but it costs much less to manufacture the generator, and connectors are prone to failure.
    Many low cost generator heads have aluminum windings. The average consumer isn't aware of this because the market for those heads is done at the B to B level.
  2. #12
    Veteran Member Mickey_Fx's Avatar
    Join Date
    Aug 2005
    Posts
    1,132
    Vancouver Wa.
    Yanmar Fx24D, Cub 3204
    I have a Subaru OBW sitting in the garage and a tiller out in the shed with a Robin EX engine. No way would I rate the Robins and especially the small EX engine under a Honda. The EX doesn't have any plastic internal parts except maybe the chain tensioner. This is a OHC design and the crank is supported by ball bearings on both ends. Very little mech noise. Engines are warranted for 5 yrs even in commercial use. You think makers of equipment intended for commercial use would pick a 2nd or 3rd tier engine for this kind of application?
    As for brushes Vs brushless, I'll take the brush design. On a brushless design there is a sizable capacitor mounted on the armature. I don't need something like that rotating at 3600 rpm and decides to come flying off. Not all that unusual for lower qlty brushless designs. If this happens it's not a DIY fix. You typ see brushless designs on low end intermittent use gensets. Not say ALL brushless design aren't decent but the majority small gensets aren't intended for extended use. Like the brushes on an automotive alt, on generators they're not a issue and last for a very long time. Need replacing, typ can be changed in a few min.
    The genset in my MH, an Onan uses brushes and they are designed for extended use. Oh, that genny turns 1800 rpm. Also have a high end Honda. A model you don't see too many of. It also is a brush design. Speed regulation is great, I've measured freq at low and high loads and freq is held to +/- .5Hz. The engine on this genny is also not your typ design. 2 cyl OHC water cooled. List price ~$4k for 6.5kW. Now out of productions. Not sure of the engine specifics but would suspect it is top notch.
    Yanmar Fx24D,
    Koyker 155 loader,
    RSB-1300 tiller
    Cub 3204, 48" mower
    Bolen 1257 GT with tiller
  3. #13
    Super Star Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    10,263
    Washington NC (Inner Banks)
    Kubota L5740HSTC, MF 2615, MF 1230, IH Super A
    within most design parameters, copper is better, significantly more expensive, and used on most quality gen heads. Hope I got that right.
    Also, there is always the option of building your own relatively inexpensively:
    Surplus Center - 13.4 HP YANMAR 2TNV70-HGE DIESEL ENGINE
    3600 rpm diesel at rated power, maybe you could run it lower
  4. #14
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    Quote Originally Posted by daugen View Post
    within most design parameters, copper is better, significantly more expensive, and used on most quality gen heads. Hope I got that right. Correct.
    Nominally rated at 10kW @ 3,600 r/m so you could conceivably run a 5 or 6 kW head @ 1,800 r/m.
    Our 3 mW TEWAC Kato's weigh in at around 25 tons each - not an ounce of aluminum in there.
  5. #15
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    Here is one of my alternators, it's the white thingy and they are brushless..
    Subaru Brand Generators-04-jpg
  6. #16
    Join Date
    Feb 2012
    Posts
    10,263
    Quote Originally Posted by Bob Rooks View Post
    I love it. An EMD for prime power? You sure will be the first on your block to have one.
    this looks like backup power for a small town.
  7. #17
    Elite Member
    Join Date
    Feb 2007
    Posts
    2,845
    Earth
    A yellow one
    LOL. Yeah, I have four of these puppies. EMD 16-710G's. 4,000 HP ea. @ 900 r/m. They power four 3,000 HP Siemens electric drive motors through a cyclo-converter control system. Pretty cool even though it's old technology.
Similar Threads
  1. Any Subaru owners?
    By JB4310 in forum Related Topics
    Last Post: 01-25-2015, 09:45 PM
  2. Subaru EH72D Oil Filters ????
    By FAZTRAC in forum Power Trac
    Last Post: 01-07-2011, 08:15 PM
  3. What to do with a rusted out Subaru???
    By shinnlinger in forum Build-It Yourself
    Last Post: 06-20-2010, 02:18 PM
  4. Subaru small engines?
    By tom4018 in forum General Lawn & Garden
    Last Post: 09-25-2009, 09:10 PM
  5. Subaru engine
    By RobertN in forum Related Topics
    Last Post: 05-31-2006, 08:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
