Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    1
    Covington Louisiana
    580 case backhoe
    Default 580 case backhoe won"t move
    Back wo"t move when you put it in gear
  2. #2
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Default
    Welcome to TBN.
    Message posted with TractorByNet v1.6.2 for iPad
  3. #3
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: 580 case backhoe won"t move
    to TBN
    Murph
  4. #4
    Join Date
    Jul 2003
    Posts
    1,824
    SW Indiana
    Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
    Well, I've made the following mistake on my Case 480F- you have to put it in gear at two different places. First, on the floor shift in picking a gear. Second, on the column between forward or reverse. Brain fart on my part, but another TBN member reminded me. (I only use it about once a year). Hope this is your problem too.
  5. #5
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,583
    Murray, KY
    265 MF / JD 310B Backhoe
    Quote Originally Posted by Billhd View Post
    Welcome. Try all the other functions of the FEL and hoe and if they work your pump should be working. Lift the tires and see if you can get them to turn when just in the air. When you shift from forward to reverse and back does it make any sounds when your wheels are off the ground?
  6. #6
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    Welcome to TBN.
  7. #7
    Elite Member Briana03's Avatar
    Join Date
    Jul 2010
    Posts
    3,292
    San Diego, California
    None
    Welcome to TractorByNet!
    I moved your thread to the Construction Equipment forum.
    Briana
    TBN Support
  8. #8
    Elite Member Bob Rooks's Avatar
    Join Date
    Feb 2007
    Posts
    2,843
    Bothell & Silverdale, WA
    Yuchai Bulldozer
    Got oil?
    Yuchai 306R dozer, Mustang 2040 skid steer, Mitsubishi MS035 Mini-Ex with four buckets and a rake, Trimble machine control GCR-2SM laser receivers, 68" Titan flail mower.
  9. #9
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    2,248
    manitoba
    Many
    I had a 580G that did something once long time ago . I think the shuttle linkage fell apart but it felt like it was engaging ?
  10. #10
    New Member
    Join Date
    Mar 2013
    Posts
    5
    Scott
    Case 580
    I just bought a 68 580 CK that was sitting when the guy I bought it from bought it and it has issues with the fuel pump timing and I guess that's why he sold it. Anyway, when I bought it the guy had changed all of the filters only to find out that there was water in the hydraulic fluid from a bad shifter boot. I ran it to test everything and to drive it on and off the trailer, well after it was run for a while it started having problems going into gear and I suspect it's because of water in the fluid and I had to rev it up to get it to move. Check your fluids and go from there. I hope this helps. Make sure you use the right fluid or at least some that's compatible with Case machines.
Similar Threads
  1. 580 c case backhoe with 207
    By Bradley Hardy in forum Parts/Repairs
    Last Post: 12-11-2011, 03:07 AM
  2. 580 C BACKHOE DOES NOT MOVE
    By HIFLYSTAR in forum Construction Equipment
    Last Post: 10-11-2011, 10:49 AM
  3. 580 C BACKHOE DOES NOT MOVE
    By HIFLYSTAR in forum Case-IH
    Last Post: 10-09-2011, 05:04 PM
  4. case 580 backhoe
    By lorenzo10 in forum Parts/Repairs
    Last Post: 10-04-2011, 09:18 PM
  5. Case 580 Backhoe - Hard start
    By llewellynsd in forum Construction Equipment
    Last Post: 01-25-2004, 09:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
