Results 1 to 5 of 5
03-13-2013, 09:53 AM #1New Member
- Join Date
- Mar 2013
- Posts
- 4
- Location
- Scott
- Tractor
- Case 580
68 Case 580 CK Timing
Hello everyone,
I just bought an old Ck in good condition and I'm having fuel problems. The machine would run with no power and wouldn't go pass a high idle so I took off the pump and went through it, checked return lines and now I'm trying to time it but I can't see the TDC on the flywheel but did find the 10 degree mark. It's supposed to be timed at 8 degrees but the pump shaft isn't lining up with the pump. I'm dreading taking the timing cover off to see if that's the problem. I know someone has been in the pump because I found an umbrella seal folded back and still looked new. This thing was sitting for a while and I have no past knowledge of what has been done.
At this point I'm thinking I have no option but to remove the timing cover, I have the valve cover off to make sure I'm at TDC and the pump still doesn't line up. Any help or suggestions would be appreciated.
03-14-2013, 03:12 PM #2New Member
- Join Date
- Mar 2013
- Posts
- 4
- Location
- Scott
- Tractor
- Case 580
Re: 68 Case 580 CK Timing
I got her fired up and running good, I still have a little smoke from the exhaust but considering how long it sat and all the fuel problems with it, I'll let it run for a while before making any other adjustments.
03-15-2013, 10:49 PM #3
Are you sure you had it at TDC , number 1 on the compression stroke ? You could be 180* out , they will still run , just not well . That would explain why you could not see the mark , you may have needed to rotate the crank another full turn as it rotates twice to every revolution of the cam .
03-18-2013, 08:51 AM #4New Member
- Join Date
- Mar 2013
- Posts
- 4
- Location
- Scott
- Tractor
- Case 580
All I could see was the 10 degree mark and not the TDC, I think I'm off by a few degrees because it lacks low rpm power but if I set the throttle higher she runs good. I also have a miss at lower rpms but when it's at about half thrittle it goes away. I also noticed someone put 1 injector in there that's from another machine and a little longer than the originals, they made a brass spacer to take up the difference in length.
03-18-2013, 04:18 PM #5
That will be your miss then , I doubt they could get the pressure, spray pattern , and atomization exactly the same as the others .
Similar Threads
case 580 k
By billdjensen in forum New Member IntroductionsReplies: 2Last Post: 10-14-2010, 10:07 AM -
case 580 k
By billdjensen in forum Parts/RepairsReplies: 2Last Post: 10-14-2010, 10:07 AM -
Case 580 CK
By REVTAYLOR73 in forum Parts/RepairsReplies: 3Last Post: 08-24-2010, 11:01 AM -
Case 580 SL
By renovxpt in forum Construction EquipmentReplies: 3Last Post: 02-20-2010, 02:24 AM -
case 580 k
By zcolt in forum Construction EquipmentReplies: 18Last Post: 11-25-2007, 10:52 AM
