Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jun 2014
    Posts
    3
    Louisville, KY
    Mustang 2050
    Default 2001 Mustang 2050 new ignition
    New member here, but not new to skidsteers. Lost key for machine and had to hot-wire it. In the process, one of the posts on the rear of ignition switch came loose, so I replaced the switch. I have power but when I turn the key to the 'on' position to start, I get Zero... Looking for a schematic or any info from the good folks here. I should have taken a picture before I took it apart...
    Ted
  2. #2
    Elite Member Bob Rooks's Avatar
    Join Date
    Feb 2007
    Posts
    2,691
    Bothell & Silverdale, WA
    Yuchai Bulldozer
    Default Re: 2001 Mustang 2050 new ignition
    Quote Originally Posted by 20012050 View Post
    Ted
    I have a 2040 but mine has a diesel engine. No ignition. I have a key switch - and a schematic for a diesel, but it will be a few days before I can get to it. Try to get a shop manual for it. Golden Eagle Equipment might have one.
    Yuchai 306R dozer, Mustang 2040 skid steer, Mitsubishi MS035 Mini-Ex with four buckets and a rake, 7' Dual Dozer with dual Trimble machine control GCR-2SM laser receivers.
  3. #3
    New Member
    Join Date
    Jun 2014
    Posts
    3
    Louisville, KY
    Mustang 2050
    Mine too is a diesel - it is a keyed ignition. Everything worked fine - and the starter has spun when I touched a wire to another while putting the wires on the back of the ignition, but just not sure how they go. It's only 4 wires, and I know the Hot wire and starter wire. Just cant seem to get it to start...
  4. #4
    Join Date
    Feb 2007
    Posts
    2,691
    Yuchai Bulldozer
    It will not start if the operator proximity switch and seat belt clasped switch circuits are open. Do you have power to the fuel solenoid valve?
    Does your engine have glow plugs?
    There is no IGNITION!
    Dubious.
Similar Threads
  1. Mitsubishi D-2050
    By daveh1 in forum Mitsubishi/Satoh
    Last Post: 11-18-2016, 09:56 PM
  2. Replies: 4
    Last Post: 07-15-2013, 06:41 PM
  3. jonsered 2050
    By npfitz in forum Chainsaws
    Last Post: 12-03-2011, 04:00 PM
  4. 2050 Mits
    By oliver28472 in forum Mitsubishi/Satoh
    Last Post: 01-15-2010, 11:15 AM
  5. 2050
    By mathteacher in forum Kubota Buying/Pricing
    Last Post: 04-22-2005, 04:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
