OP
Thumbs Up Farm
Yes once "My Komatsu" account was set up I was able to copy and paste all available illustrated parts list for the entire machine. It took a while but I got every section.
From what I understand the only places that fluid can leak into is either the outside of the machine (under the seat is a likely place) OR worse the steering clutch / break cases one on the left, one on the right. I do not see a way the clutch pump fluid could get into the final drive transmission.
The Steering clutch / break cases should be completely dry, the final drive transmission is in the center and divides the two halves. Under the final drive there are three drain plugs, the center is the final drive, the left and right are for the steering clutch / break cases. If you remove the left and right drain plugs for the steering clutch cases there should be no fluid in there. Maybe a bunch of rust and dust.
Thanks, again!
I am still trying to get "My Komatsu" set-up. They promised to at least let me know something today. They seem like really nice helpful folks but so far I am making no progress in getting set-up.
I will remove the drain plugs for the steering clutches first and see what comes out. I don't think there will be any fluid because neither track slips when I push against something immovable. They both spin at the same rate. I will also remove the brake band covers, adjust the brakes, and vacuum whatever dust and debris I can out of the clutch drains at the same time, prior to putting the brake band adjustment covers back on.
I suspect you are right about the clutch pump leaking under the seat. Based on your picture above, it looks like a pressure tube from the pump sealed by o-ring 26. Which, I assume, feeds the steering clutches valve. But, how does the oil return from the steering valve to the clutch pump? Is there perhaps a low pressure return hose? Any speculation on where the leak might be under the seat or how to repair it? The seat brackets and adjusting mechanism is virtually gone due to rust. So, I will probably try to remove the entire seat plate/platform with seat attached if that is possible. Maybe then I can locate the leak.
The rear trans is obviously over-filled. So, maybe I should drain and refill it or at least drain off the excess?
