oldafretired
Looking for a replacement for a BH77 backhoe on a Kubota L3901 tractor. I let my brother use the L3901 to move snow this winter since his old tractor broke down. I'll probably end up giving him the tractor and BH77 so I won't have a backhoe anymore. I've been using the backhoe to mainly dig up stumps after cutting down pine trees on my heavily forested 10 acres. The largest stumps are probably 15" in diameter or so but most are smaller.
I think it used to take me over an hour with the BH77 to dig up the larger stumps using a 16" bucket. I'm thinking of getting a mini excavator to replace the backhoe. I really want to be able to put the excavator in my shop which has a garage door opening that is 96.5" high so the choices become limited. The Kubota KX71-3S and KX91-3S2 are right at 96" high according to their specs so if the specs are accurate, either should fit. The KX71 with cab is supposed to be a half inch shorter but I prefer an open station. Would either one of these excavators be good for removing stumps and would they should be able to get a pine stump out significantly faster than the BH77? What kind of performance difference would there be between the KX71 and KX91?
Thanks!
Thanks!
