Page 7 of 7 FirstFirst ... 4567
Results 61 to 68 of 68
  1. #61
    Gold Member 1stDeuce's Avatar
    Join Date
    Aug 2016
    Posts
    422
    Mancos, CO
    Massey Ferguson 1455v
    Default Re: Talk to me about owning a Dump Truck
    Wow, that's a great looking Loadstar hslogger!! I had the chance to buy a 3 yard dump loadstar, ~1973 vintage. I passed, thinking at the time that it was too much of a project.
    I hope my truck looks half that nice once it's painted... I currently have about $4800 into it, not including the plow or scraper. I still haven't managed to sell the spare 366 that it came with either, so I'll get some money out of that if I ever find a buyer.
    The hoist showed up Friday, so I'll get working on the install later this week. Then I need to bleed the brakes really well and see if I can get some pedal. I did a panic stop in it the other say and was NOT impressed, but I may have simply been out of pedal travel...
    The first pedal apply goes pretty much to the floor before you get any stopping at all. Because it's Hydrovac, both the apply and return of the pedal are terribly slow, so you currently have to anticipate the need to stop by 15 seconds or more if you want good pedal and decent braking power.
    Shoes are all adjusted tight to the drums, so I think there must be air in the system somewhere... Original owner said he bled it numerous times and never improved the pedal. I'm thinking a pressure bleed might purge whatever air is still there. If that doesn't work, I'm scraping the hydrovac for a newer hydroboost setup with a dual reservoir master. I know I can get that to bleed out, and I'll probably get quite a bit more braking power too...
    "I used to be a people kinda guy, but people ruined that for me..."
    My tractor thread: A loving home for a neglected MF1455v
  2. #62
    Join Date
    Aug 2016
    Posts
    422
    Mancos, CO
  3. #63
    Gold Member
    Join Date
    Jan 2009
    Posts
    467
    western oregon
    currently l4400 stick
    Thanks. The shiny paint is about four years old now. Photo is only a year old. It's Mopar " adrenaline red" Clear coat makes the diff in the long run. Truck lives out doors its' whole life. I was just a corn binder fan from growing up.Family and friends had them. Always liked the rounded fenders, transmissions and the coolest dashboard that existed. They were all iron through and through.
    4400GST SSQA bucket,
    Landpride forks,
    Bobcat manure forks
    five ft Old rotary mower
    Post hole auger
    Leon rear blade
    landscape rake
    carryall
    Lx178 LX172 Deeres
    Husky 372s 394
    little Stihls
    haywagons
    big horses
    sheep
    Loadstar FBD
    Woodmaxx hydraulic chipper
  4. #64
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,214
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Dumpy is still going strong here. Bought it new in '93, and have worn holes though the bed from hauling numerous loads. Off the top of my head, well over 6,000 tons, but mostly only hauling short distances of a few miles. Plus 2-3 trips a year to the limestone quarry, which is 25 miles away. Has right at 75,000 miles on it, and still going strong.
    Attached Thumbnails Attached Thumbnails Talk to me about owning a Dump Truck-dsc01912-jpg
  5. #65
    Join Date
    Aug 2016
    Posts
    422
    Mancos, CO
    After a week of long evenings, I am happy to report that I hauled the first load with it today.
    Talk to me about owning a Dump Truck-ncm_0155-1-jpg
    This is 10k of road base (3/4 minus). Power is not bad, was only down to 45 on the long grade here, which isn't too bad considering we're at 7k'.
    Brakes stop pretty well, and I power bled them so no more pump to stop.
    I checked the lift at the quarry and it will dump this load without issue. Actually, it'll probably dump a LOT more considering I got a 20k hoist under there... Could have gone with the 16k, but the 20k was only $50 more...
    I need to order a mesh tarp, and I have two mudflaps to hang.
    Perhaps I'll paint it sometime this summer... The gray/tan/green thing is a bit homely...
  6. #66
    Join Date
    Aug 2016
    Posts
    422
    Mancos, CO
    This is 10k of road base (3/4 minus). Power is not bad, was only down to 45 on the long grade here, which is better than I expected considering we're at 7k'.
  7. #67
    Super Member 4570Man's Avatar
    Join Date
    Apr 2015
    Posts
    6,864
    Crossville, TN
    Kubota L3240, Kubota B7100, Kubota F2560, John Deer, F525 Mule 600
    Default Talk to me about owning a Dump Truck
    Hereís my second dump truck. Iíve got a 14Ē flat bed with a dump to go on it but I may part ways with it before I do that.Talk to me about owning a Dump Truck-img_0772-jpg
  8. #68
    Join Date
    Oct 2014
    Posts
    874
    San Diego, Tx
    New Holland TC40 DA, John Deere 17D mini-ex, Hyster SX50 forklift
    I finally finished up the inframe on my truck in March, got all the little leaks fixed, replaced some lights, got it inspected and renewed the registration. I'd just putted around with it for that stuff as an easy start for the new motor and today I gave it a real test. I drove 48 miles to the dirt yard, got 5.5 tons of compost and drove back, everything ran great. My front tires are out of balance and I get some vibration starting at about 55-60 so I stayed at 55 or less, I can't find anyone willing to balance these old tube tires, I'm going to try the Fleetpride next.
    I realized after I got loaded that the back tires needed air, they call for 110 but, the gas station I stopped at could only do 70 so I got them there and got home fine. After dumping the load, I went over to the shop and checked all the fluids, coolant was still full and the oil looks like new. I aired up the back tires, got the first one to 100 pounds and then couldn't get it any higher after 5-10 minutes when it dawned on me that the regulator was set to 100 pounds. DOH! I put the air line direct to the tank and got them all up to 110 so I'm good to go.
    I'm going to put a tailgate on it in the next week or two, I just tarped over everything today, and then I'll make the 65 Mile drive to the landfill to get some mulch. Once we get the 2nd garden done and I'm caught up with work, it'll be time to start getting asphalt millings for the driveway.
    It's good to have her running again, she's incredibly useful to have.Talk to me about owning a Dump Truck-img_20180320_161429961_hdr-jpeg
Similar Threads
  1. Dump truck vs dump trailer
    By IMCA38 in forum Trailers & Transportation
    Last Post: 05-25-2017, 09:10 AM
  2. Lets talk car/truck/tractor batteries ??
    By coobie in forum Trailers & Transportation
    Last Post: 10-07-2016, 06:11 PM
  3. turning a 3/4 ton truck into a dump truck??
    By BWS in forum Attachments
    Last Post: 08-04-2016, 12:49 AM
  4. Talk me out of a new truck?
    By Chris2 in forum Trailers & Transportation
    Last Post: 08-30-2013, 09:35 PM
  5. Here we go again, truck talk.
    By jcmseven in forum Trailers & Transportation
    Last Post: 11-04-2011, 08:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
