hilld
Gold Member
Make sure the voltage regulator is plugged in, if that is what I am seeing mounted on the right inner fender.
Derek
Derek
EddieWalker said:Here she is all done and ready for work!!!
I thought about cleaning and painting the air cleaner, but I really couldn't justify why I should do it, other than kill some time. In a week, the rest of the engine will look like the air cleaner anyway. hahaha
There is one more problem to address. On the firewall you'll see the brake fluid resivoir. It's not the master cylinder, that's under the drivers seat. It's this oversized, vacume asssisted monstrosity that is unlike anything I've ever seen before. When I hit the brakes, the engine dies. At first I thought it was a massive vacume leak from the master cylinder. After pulling it apart, my Dad figured that a couple of seals were bad and we're probably letting hydraulic oil into the engine. I don't know how bad this is, but it's not good.
It's not worth a new thread, since I should have it fixed after the holiday with a few dollers worth of rubber seals. Kind of like wide, flat o-rings.
The other picture is of my dumptruck with the hood on.
Thanks to everyone for your help and suggestions,
Eddie
