Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Sep 2009
    Posts
    8
    Default 3 Hp Craftsman kill switch
    First thank you for allowing me to post!
    I'm working on a Craftsman tiller model 785 62243 203 with a B&S engine. Carb is a pulse jet. It runs fine, my only question is where to route the ground wire coming from under the flywheel? I have read that it gets hooked up to the throttle linkage somehow but it's just currently hangin in the wind. Can I just install a momentary switch.
    Model for Briggs is 80202-1017-02 81060803
    Thanks
  2. #2
    Join Date
    Jan 2009
    Posts
    124
    Loudon, New Hampshire
    Agco ST35
    Default Re: 3 Hp Craftsman kill switch
    Yes, a switch to ground will kill the engine.
    But, the way it's supposed to work is when the throttle is pulled to the "stop" position there should be contact switch that grounds the ignition. Usually white plastic, close to the carb, and very near the end of the throttle cable.
  3. #3
    New Member
    Join Date
    Sep 2009
    Posts
    8
    that's what I was looking for, but don't seem to have one on this engine
  4. #4
    Join Date
    Jul 2008
    Posts
    127
    Kansas City
    JD 4400
    Briggs lists it as a 297472S Stop Switch. it attaches to the throttle linkage. There is one listed on eBay today if you want to see a picture. It has an insulating nylon base and a spring steel clip that holds the primary wire to the magneto. When the throttle is moved to the slowest position the bellcrank makes contact with the spring steel clip and kills the engine.
  5. #5
    Join Date
    Jan 2009
    Posts
    124
    Agco ST35
    Go to a B&S service dealer and ask for an ignition kill switch.
    Another thought. Some machines use a switch or key to kill the ignition, but if you have a wire coming from the coil you probably need the kill switch on the throttle.
  6. #6
    Platinum Member zman007007's Avatar
    Join Date
    Jun 2009
    Posts
    520
    Gray Court,S.C.
    B7100HST-E
    just a plain off and on toggle switch would work and be cheaper. zman
  7. #7
    Join Date
    Jan 2009
    Posts
    124
    Agco ST35
    Quote Originally Posted by zman007007 View Post
    The Briggs kill switch retails for $3 or less. Hard to get much cheaper than that.
  8. #8
    New Member
    Join Date
    Sep 2009
    Posts
    8
    Thanks guys, I'll enquire, may go with the switch. I'll let you know
  9. #9
    New Member
    Join Date
    Sep 2009
    Posts
    8
    I've enclosed a picture hopefully this helps
    Attached Thumbnails Attached Thumbnails 3 Hp Craftsman kill switch-img_0001-jpg
  10. #10
    Join Date
    Jul 2008
    Posts
    127
    Kansas City
    JD 4400
    Diagram nuber 348 is the stop switch. The new part number is 691941. 3 Hp Craftsman kill switch-briggs-carb-gif
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
