Transmission Problems???
   / Transmission Problems??? #1
Surfmonkey
Craftsman 24HP 42" 917.287261
I have a Craftsman 24 HP 42" Electric Start Automatic Transmission. The Model Number is: 917.287261
The tractor would not travel at high speed. Engine runs and blades turn but the tractor would not get up to high speed. If I went in a straight line, it would gradually pick up speed. When I would make a turn, it would not get up to high speed.
This morning, it will go in reverse (but not fast) and will not go forward but a few feet then stops. Slight groan from under the seat, guessing it is the transmission.
Any ideas on what problem might be? Can I do the tranny rebuild myself even though I am not a mechanic, but am somewhat mechanically inclined?
   / Transmission Problems??? #2
3 year old Craftsman 42' cut.. - Tractors Forum - GardenWeb
Is this you ? Did the problem come back ?
If so then you have a transmission problem. They can be repaired. The first step would be to get the model number and manufacturer of the transmission and post it here. Or take a look at the website of the manufacturer and get their phone number for the parts dept. They can help on the phone.
Steve
   / Transmission Problems??? #3
my hydro needs purged occationally, just needs the air purged from system, tells it in owners manual to purge system if it gets slow or sluggish, heres how i do mine, the free wheeling lever needs to be engaged, then start engine and move forward control lever slowly forward and back over and over for a few minutes. if you have foot pedal then push pedals in and same with reverse pedal. do that for a bit and see if the improves the motion, if not then look for slipping belt or worn balt, oil or grease on the drive belt.
   / Transmission Problems??? #4
might also check the "free wheeling" knob and make sure it's not partially in free wheeling mode.
   / Transmission Problems??? #5
I had a very similar problem with my Craftsman 20hp 42" (DLS 3500). The problem is quite common. I removed the transmission dumped out all of the fluid via the factory fill port. I flushed it with some Marvins Mystery Oil and refilled it with 20w50 synthetic oil. It ha been running like a champ ever since. The job sounds intimidating but it is rather easy and almost enjoyable.
   / Transmission Problems??? #6
I found the lever to my main drive belt idler pulley needed lubrication; the belt never squealed but it was slipping. Also I ground down the bolt head that was preventing my shift lever arm from fully moving rearward and giving me full reverse.
