After sitting for the winter...
I've flushed the fuel line and emptied the carb bowl. The engine will start with a bit of fuel splashed on the carb, but then dies out in few seconds.
Confirmed the fuel pump is pumping by disconnecting from carb and starting.
Confirmed the fuel works by taking that from the pump and using it in the carb for a starter.
It appears to have a fuel cutoff, how can I test that? That part is expensive to just run out and buy.
