Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2009
    Posts
    128
    land of living sky
    B434 ,V 700 and 1086
    Default 2 for 40.00
    I bought 2 sears mowers today at a garage sale one has never cut a blade of grass but carb is half apart and no float bowl ,not sure what it is going to cost ,the other one must have hit something and cut off both shear bolts in blade and maybe the key in the fly wheel the way it is acting ,it would smoke but kick .The new one has a Kohler engine hadn't seen a mower with that engine what should I expect for it. If my mower had sheared a few things instead of bending the crank I wouldn't have been on the market ,moving scrap but not removing it causes issues.
  2. #2
    Ken
    Ken is offline
    Join Date
    Apr 2000
    Posts
    1,105
    North Central Arkansas
    John Deere 4520,
    Default Re: 2 for 40.00
    Quote Originally Posted by Whatswrong View Post
    Blade is the flywheel on most engines in push type mowers.
    Carb. on Sears designed to fail.
    Little push bulb for choke (push 5 times before starting) if air leak buy new carb.
    All my Sears tools fail before the paint fades.
    ken
  3. #3
    Join Date
    Oct 2009
    Posts
    128
    land of living sky
    I got them both home from the local small engine repair man ,he had the older self propelled one running in less than an hour I have used it a few times and it runs nice I sure like the mulching feature. The new one had to have new carb,filter and filter cover and a couple bolts these parts cost about $80.00 this is a 2011 mower about a 375.00 mower .No labour because I had given him parts for his water softener this spring.Not sure if I should sell the new one or use it.
  4. #4
    Join Date
    Oct 2009
    Posts
    128
    land of living sky
    So the reality is 2 for 120.00 so may not be so cheap.
  5. #5
    Join Date
    Apr 2012
    Posts
    94
    Foothills of NC
    94 Craftsman GT6000
    Maybe more than you hoped, but still not bad at all.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
