Results 1 to 8 of 8
  1. #1
    Member Rocketcaver's Avatar
    Join Date
    Jan 2010
    Posts
    34
    Southern Illinois
    New Holland TC25D (2002)
    Default 54" deck mandrel issues
    I'm getting ready to work on the deck of my 917288580 lawn tractor, it's the 54" deck. This mower is 3 or 4 years old.
    The left mandrel assembly has been making noise lately, and I figure it's time to look at the bearings.
    There is a grease zerk on the end of the spindles, and I do give them a couple shots per the manual, but does that really do anything? I mean, looking at the parts online, it looks like both bearings are sealed, so where does that grease go? Am I missing something here?
    I took the deck off yesterday to check things out in prep for removing the mandrel, and for the life of me, none of them feels any rougher than the others. The middle one spins the most freely; with blade and belt removed it will coast for several seconds when given a spin. The other two don't coast as long, but I don't feel any roughness or any end or side play in the bearings. I have not yet removed any of the mandrel assemblies from the deck.
    Symptoms: When mowing everything will be fine, then suddenly it will make a... well, not a squealing noise but more like a loud buzzing noise... and vibrate for a few seconds, then that will stop and everything is normal again until a couple minutes later when it happens again. I checked the other pulleys, those feel smooth and spin freely also.
  2. #2
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,523
    Ontario, NY
    Kubota BX24
    Default Re: 54" deck mandrel issues
    Thats the problem with the box store type lawn mowers. they tend to use cheaper designs that wears out more easily and needs replacing. I would just replace the bearings. Some mandrels you can keep your jackshaft and replace the bearings. Some you must buy the whole thing. good luck
  3. #3
    Join Date
    Jan 2010
    Posts
    34
    Southern Illinois
    Yes, they are cheaply made, I will agree with that.
    I do plan to take the assembly apart and replace the bearings if possible, I was just curious about the greasing, as it looks like there is not a way for it to be doing any good. I'll find out when I get it all apart I guess.
  4. #4
    Join Date
    Aug 2012
    Posts
    149
    Storrs, CT
    Farmall H, TC40DA, Farmall 200 F spreader, Dolmar saws, lots of junk
    Quote Originally Posted by Rocketcaver View Post
    I'm thinking that the noise might not be from the mandrels. If they are smooth turning and don't have any end play, the bearings are probably ok. Have you checked the idler pulleys? Those are more likely to have bearings go.
  5. #5
    Join Date
    Jan 2010
    Posts
    34
    Southern Illinois
    I didn't notice any thing amiss with the idlers either. I will double-check everything when I look at it again tonight.
  6. #6
    Join Date
    Jan 2010
    Posts
    34
    Southern Illinois
    Even though I still couldn't feel anything wrong with the old bearings once I got the old mandrel off the deck, I went ahead and installed the new one; noise and vibration solved.
    Now I'll see if I can get the old assembly apart with an eye towards rebuilding it for next time.
    Thanks for your help.
  7. #7
    New Member
    Join Date
    May 2013
    Posts
    17
    franklin KY
    ford 2000
    i had a simmialr problem on my cub cadet i took all 3 spindles apart and took the inner oil seal out of the bearings with a screwdriver now the grease is actualy getting to the bearings dont worry you cant blow the outer seals out of the bearings their is a releif hole in the side of the mandrell
  8. #8
    Member
    Join Date
    Jul 2014
    Posts
    25
    Mid Michigan
    2013 Massey Ferguson 1529
    I have a similar problem on with my 54" deck on a YS5400. I was thinking the spindle but like you, I spun them and didn't feel anything. I guess I will just have to replace the one I think is bad and see what happens.
Similar Threads
  1. 60" 7 iron vs 54" or 62" deck on 700 series
    By KennedyDiesel in forum John Deere Lawn & Garden
    Last Post: 07-13-2012, 06:13 PM
  2. Are there any issues with Gator Blades on a BX1500 with a 54" deck ?
    By dex3361 in forum Kubota Owning/Operating
    Last Post: 05-02-2010, 08:52 AM
  3. Mandrel cups for old Sears tractor
    By BrianinMichigan in forum Craftsman / Sears
    Last Post: 04-13-2010, 05:15 PM
  4. Mower Deck: "Float" or "Hang"
    By ancientlake in forum General Lawn & Garden
    Last Post: 04-25-2008, 11:29 PM
  5. Adding Zerk to mandrel
    By Syncro in forum General Lawn & Garden
    Last Post: 07-10-2006, 11:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
