2166 alternative drive fluid
   / 2166 alternative drive fluid #1
edjones72
Member
South Georgia
Yanmar YM2210, Cub Cadet 2166, JD2940, Mustang 440 skidsteer
What is everyone's thoughts on using something other than Cub Cadet brand drive fluid in a 2166 transmission. The Cub Cadet brand is extremely expensive compared to other oils. Any thoughts or experiences would be greatly appreciated.
Eric
   / 2166 alternative drive fluid #2
hi edjones72
There is alot of threads on this.Just look at some old theads i hope that helps.IMO i would get the cub oil.It may cost more but why take a chance,it's not like you have to change it often.
good luck
   / 2166 alternative drive fluid #3
Lots of debates on this. Shell Rotella-T 15w-40 works flawlessly in the transaxle on my 2005 model year 2544. Mine specs Cub Cadet Drive System Fluid Plus. FWIW, I would not hesitate to use ANY high quality heavy-duty engine oil, preferably synthetic/semi-synth, in the 40-50wt range.
Joel
   / 2166 alternative drive fluid #4
(oops, posted my reply in the wrong thread)
   / 2166 alternative drive fluid #5
Joel
Joe where did you get the specs for the CC drive fluid. I, and my dealer, would like to know. He said MTD wouldn't tell him.
   / 2166 alternative drive fluid #6
Moe, I called Hydro-Gear directly and spoke with one of their engineers about the oil. He faxed me the data sheet. The oil is made by Shell and is called Shell TTF-SB. Per specs, it's not a very impressive oil. Just a run of the mill synth blend heavy-duty engine oil. I've got the data sheet posted here on other threads. So you don't have to poke through a pile of threads, here it is:
Joel
   / 2166 alternative drive fluid #7
Thanks Kub...
   / 2166 alternative drive fluid #8
Kub I have searched the internet and can't come up with a source for that fluid. Have you purchased any and if so where did you get it??
Thanks
1986 Ford LNT9000 Dump Truck (A56438)
1986 Ford LNT9000...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A60430)
2022 FORD F-750...
JOHN DEERE 9560R SCAPER SPECIAL TRACTOR (A60430)
JOHN DEERE 9560R...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2015 Forest River Rockwood Freedom S/A Pop Up Trailer (A59231)
2015 Forest River...
