I own two Cub Cadets (128 and 149). Both have rusty 44" decks with manual lift. As you probably know, these models were the earliest wide frame design. From what I can tell, Cub Cadets of that era came with the first (earliest) 44" mower that is somewhat different than later 44A and 44C.
Anyway, I just drove 14 hours to fetch a brand new 44C deck. It came complete with the 44C mower support assembly (mule drive and arched deck lift frame).
Should I adapt an old 44" deck frame to fit the new 44C deck or should I try to adapt the newer 44C mower frame assembly to fit my early tractor?
The only precautions I found through searching were to stay away from the taller, high vacuum GT decks (newer than 44C) because they will not fit under the older tractors.
I understand there may be an issue with mule belt width & I'm not sure how to best address it. I think my PTO used a thinner belt compared to a 44C tractor. Perhaps I need to swap the center pulley on the 44C deck or something.
Any thoughts greatly appreciated.
