Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    May 2010
    Posts
    5
    Default 42 rzt pto major problems
    I have been having problems with the pto engaging and disengaging on its own while mowing. i have it all torn apart, both neurtral switches on the handels read over 7 volts then read zero when i push the button. both switches under the handles that engage the pto when going forward read around 11.57 when button is released and when pushed in connection reads zero compleatly open. I do not know how to check the park break switch lots of wires on this one. I see a relay but does not seem to have any wires from it going to the clutch. I can engage the pto and when pto actually engages wires at the pto show over 12 volts and then when i hear it disengage I have no voltage at the pto. I checked the pto switch it has over 12 volt lead and when i pull the whitch the blue wire going to the clutch i assume has over 12 volts when the clutch disengages still has over 12 volts on the blue wire. everything seems to be working. the only voltage drop seems to be at the clutch am i missing something. I ran a jumper wire on a toggle switch from the battery strait to the pto to ensure over 12 volts at all times to ensure pto was not bad worked like a charm was able to mow lawn. of course i do not want to do this or damage my pto can anyone think of a what this might be. Thanks
  2. #2
    Veteran Member JTKub's Avatar
    Join Date
    Apr 2005
    Posts
    1,560
    West Falls, NY
    Cub Cadet Z-Force 44
    Default Re: 42 rzt pto major problems
    Whoa...Dude!! Way too many voltage readings here. Obviously I'm no Master Mechanic, but you should have either 12VDC or nothing. Anything less would indicated a weak battery or a short somewhere. I'd jumper the two lap bar switch connectors to take them out of the loop and jump the parking brake connector (for troubleshooting purposes only of course) and go from there. The seat switch should also be a normally closed FWIW.
    Joel
    Tractors of the past:
    2010 Cub Cadet Z-Force 44 fab
    2005 Cub Cadet 2544
    1979 Case 220
    2003 Yard Machines 17hp 42" transmatic (crap-matic)
  3. #3
    Join Date
    Jun 2008
    Posts
    100
    Cape Breton, Canada
    Kubota B7510
    Have a look at attached, see if this helps.
    Donnie
    Attached Files Attached Files
  4. #4
    Member
    Join Date
    Aug 2009
    Posts
    34
    Avon, NY
    John Deere (2) CubCadet(2)
    Usually dirty connection, bad switch or relay.. (relays most common..)
  5. #5
    Bronze Member turnerbend's Avatar
    Join Date
    May 2006
    Posts
    96
    Rome, Ga.
    Yanmar 1500
    The PTO will engage when you go forward and disengage when you go backward. To correct that, jump the reverse switches on the lap bars.
Similar Threads
  1. cub cadet 42 rzt pto problems
    By dwheelerii in forum Parts/Repairs
    Last Post: 05-24-2010, 08:28 PM
  2. RZT 50 PTO disengaging in reverse
    By kevinhuth in forum Cub Cadet Tractors
    Last Post: 04-22-2008, 09:23 AM
  3. Mahindra 575 PTO shaft
    By Tim Stuart in forum Mahindra Owning/Operating
    Last Post: 01-14-2008, 02:56 PM
  4. Mowing TC40A PTO engagement with a rotary mower
    By mundamanu in forum New Holland Owning/Operating
    Last Post: 05-31-2007, 08:46 AM
  5. Why use clutch with GST?
    By Jay4200 in forum Kubota Owning/Operating
    Last Post: 10-09-2006, 01:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
