Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Apr 2010
    Posts
    3
    Default 125 blowing sparks
    So I got this 125 off a co-worker that parked it outside his barn 1.5yrs ago. I had to rewire it and replace the voltage regulator and rebuild the generator to get some sign of life. Then I did'nt have but -/+25psi compression so I dumped some 30w down the cylinder and left it for a couple weeks. This sat. I decided to try it and she fired right up billowing smoke out the exhaust like none other. Drove her around till the smoke stopped and my girlfriend said when I passed her she was getting hit by bits of "stuff" and noticed sparks coming out the exhaust. Do you think that the rings are falling apart or junk in the muffler.
    Second issue that makes me feel she needs to be refreshed is she wont start if I hook up the mower belt. She tries but just cant do it. The mower deck seems to move ok so I assume she just dont have the umphh to run under load. Kind of odd though cause she will drive around.
    Who has the best deals on parts if I do need to rebuild? Im a full time student so I really have to keep cost down.
    All thoughts are welcome.
  2. #2
    Join Date
    Mar 2010
    Posts
    715
    Default Re: 125 blowing sparks
    sounds like its carbon,run it like ya stole it and see if it doest come around.Sea foam is a very good product so try adding to fresh fuelDave
  3. #3
    New Member
    Join Date
    Apr 2010
    Posts
    3
    I did actually add some sea foam to the fuel just before I tried to get it running. It probably couldnt hurt to add more now that the old fuels gone. I would like to rebuild the carb but I cant seem to find a kit for a decent price. When I do a search all I find is $200+ carbs for sale not the kits to rebuild them.
  4. #4
    Join Date
    Mar 2010
    Posts
    715
    another thing you can do if the sea foam won,t cure it,if its a single kohler pull the head off (very easy to do) and bring piston up to top dead center and wire brush the top of the piston clean.Remove the muffler and get any crap in it out.It sounds to me to be a very simple fix.Dave
Similar Threads
  1. Starter Solenoid throwing sparks
    By LaytonAg in forum Yanmar
    Last Post: 05-05-2010, 03:30 PM
  2. Snow Equipment Owning/Operating Snow blowing rules of thumb
    By smfcpacfp in forum Snow Removal
    Last Post: 02-13-2010, 04:41 AM
  3. 4720 keeps blowing ignition fuse
    By Karl2 in forum John Deere Owning/Operating
    Last Post: 05-05-2009, 06:31 PM
  4. TN 65 keeps blowing fuse when you try to start it
    By Robert_in_NY in forum Parts/Repairs
    Last Post: 04-27-2009, 04:51 PM
  5. What the?!?! Sparks!
    By DaveNay in forum Parts/Repairs
    Last Post: 04-01-2005, 06:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
