Hey guys, long time listener, first time caller.
I have an 07 2544. Yesterday I pulled the deck off to sharpen the blades and change the oil. When I got the deck off, I noticed that the pulley that drives the deck belt may be misaligned. This is the pulley under the deck PTO pulley. Two pulleys are stacked that swing away when you release the handle in the deck.
I noticed that the deck belt is making contact with the right side deck lift mount. It looks like the pulley is out if adjustment by about 1/4" to 1/2" and I can't figure out how that happened. Ive not enabled the PTO since I noticed this, and it looks like the yellow paint on the deck mount (where the belt would be rubbing) is still there, like it's not been ran with this issue.
I operated the handle that loosens and tightens these pulleys some yesterday to see if it would self adjust but it didn't seem to. I also didn't notice a way to adjust the two pulleys either.
Any thoughts?
Any thoughts?
