Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Feb 2012
    Posts
    6
    Granville, Ohio
    Cub Cadet 2550
    Question 2011 Cub Cadet Tank L60
    My dealer has a few of last years model(2011) at a discounted price. I was in the market for a new tractor for mowing about 2.5 acres but, Cub hadn't crossed my mind. The price is so good I'm taking it under serious consideration. Anyone out there own a 2011 Tank? Is it a reliable machine? Does it have trouble in wet grass? Please share what you know . Thanks!
  2. #2
    Veteran Member scoutcub's Avatar
    Join Date
    Aug 2008
    Posts
    2,363
    Ohio
    Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
    Default Re: 2011 Cub Cadet Tank L60
    Don't own an 11, but own a 2007 M72 tank with the diesel. From my limited experience with it, it is a mowing stallion. You can mow very fast and really cut down mowing time.
    Very reliable and built like a ....well.....tank.
    Not the best on the slopes I have though, and it's spent most of the time in the garage. I bought it for a house we WERE going to build which will have a huge lawn, not that build is in question....actually doubtful at least for a few more years.
    For wet grass, it's OK but will tear up the grass a bit if you do a 180 spin on a dime. Just have to exercise a little caution.
    I'll probably be selling my M72 this spring......hate to, but not using it enough. I'll probably need it right after I sell it.....
  3. #3
    New Member
    Join Date
    Feb 2012
    Posts
    6
    Granville, Ohio
    Cub Cadet 2550
    Thanks ScoutCub.
  4. #4
    Join Date
    Aug 2008
    Posts
    151
    NWWisconsin
    Cub Cadet GT2542, Sc2400
    If memory serves me correct, the L series has a few less features than the M series tanks but still runs the same hydro pumps and motors... which is a good thing. For your situation it should serve you well, plus you can always add a suspension seat later if needed.
  5. #5
    New Member
    Join Date
    Feb 2012
    Posts
    6
    Granville, Ohio
    Cub Cadet 2550
    Thanks Vince
  6. #6
    Veteran Member JTKub's Avatar
    Join Date
    Apr 2005
    Posts
    1,560
    West Falls, NY
    Cub Cadet Z-Force 44
    That's a nice heavy-duty zero turn. Separate pump & wheel motor drive. Heavy deck & hanger hardware etc. At ~1100lbs, traction shouldn't be too big a problem, but like anything, you have to take it easier on wet grass to avoid a mess.
    I owned a Z-Force 44" fab for two seasons and enjoyed it, but found my Cub 2544 to be more comfortable for the conditions I had at the time; Hilly and bumpy.
    The Tank is bigger, wider, heavier and has much more allowable up/down movement of the deck, so it's a better machine than a Z-Force.
    Joel
    Tractors of the past:
    2010 Cub Cadet Z-Force 44 fab
    2005 Cub Cadet 2544
    1979 Case 220
    2003 Yard Machines 17hp 42" transmatic (crap-matic)
Similar Threads
  1. Replies: 4
    Last Post: 11-17-2011, 08:26 PM
  2. Snowblower Cub Cadet QA-42A
    By dpizzino in forum Attachments
    Last Post: 11-02-2011, 08:06 PM
  3. Cub Cadet 42' 19hp JUNK
    By Melissa H in forum Cub Cadet L&G
    Last Post: 07-20-2010, 10:28 AM
  4. Cub Cadet Tank
    By jimskio in forum Cub Cadet L&G
    Last Post: 07-12-2010, 10:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
