Results 1 to 7 of 7
  1. #1
    Member GRB's Avatar
    Join Date
    Jul 2005
    Posts
    36
    Mount Airy, Maryland
    2005 Cub GT 2550
    Default GT2550 PTO Problem
    Good Afternoon,
    I have a 2006 GT 2550 with 350 hours on it. I did some regular maintenance yesterday (change oil, clean pre-filter, grease, switch out blades for newly sharpened, washed, etc.) This morning, I went out to mow and the PTO suddenly now comes on, runs for a minute or two and then shuts off. Pull it on again and it will run for a minute or so, then shut off. I thought maybe I got some water in the switch, so I pulled it and hit it with some De-Oxit, but the issue remains.
    Sound like just coincidence that the PTO would fail or did I get something way to wet when I washed it yesterday?
    Thanks for any input.
  2. #2
    Join Date
    Mar 2008
    Posts
    758
    Default Re: GT2550 PTO Problem
    would first chk battery - a marginal batt will let that happen.
    M/W, lose the hose or pressure water wash thing - L&G tractors don't like it - they are not designed/built to withstand the corrosion that happens at elect connections/switches/etc. Better to use comressed air or an electric leafblower after each cutting session.. then just a damp rag only on body as needed.
  3. #3
    Member GRB's Avatar
    Join Date
    Jul 2005
    Posts
    36
    2005 Cub GT 2550
    Thanks for the response. I finally figured it out this evening. The relay for the PTO up under the dash was factory wire-tied to the wiring harness with the open end up, so evidently I got water in there while washing the tractor. I took it apart and it was definitely wet. Dried it out, used some De-oxit and viola...Runs like a champ.
    I normally just use compressed air to clean it, but I had been mowing a couple of days after rain and it had gunk stuck all over it. Learned a good lesson, guess I will make sure I don't get it wet under the hood next time.
  4. #4
    Join Date
    Mar 2012
    Posts
    143
    Sydney , Australia
    Cub Cadet Gt2550
    Hope you do not mind , the box on the back of your mower could you get a closer photo please
    My Wife said I do not listen
    At least I think thats what she said
  5. #5
    Member GRB's Avatar
    Join Date
    Jul 2005
    Posts
    36
    2005 Cub GT 2550
    Tracter, here you go. It is just a Stack-On tool box from Tractor Supply and couple of pieces of angle iron bolted to the frame rails.
    Attached Thumbnails Attached Thumbnails GT2550 PTO Problem-rear-jpg   GT2550 PTO Problem-opentoolbox-jpg
  6. #6
    Join Date
    Mar 2012
    Posts
    143
    Sydney , Australia
    Cub Cadet Gt2550
    Looks good that deserves a double thumbsup
  7. #7
    Veteran Member JTKub's Avatar
    Join Date
    Apr 2005
    Posts
    1,560
    West Falls, NY
    Cub Cadet Z-Force 44
    Quote Originally Posted by GRB View Post
    Good find GRB!
    Thanks for posting the follow-up on that. I do recall having to tidy up a lot of the wiring on my 2005 model year 2544. The bundle(s) of relay pigtails on mine originally looked like someone got a running start and stomped them in.
    Joel
    Tractors of the past:
    2010 Cub Cadet Z-Force 44 fab
    2005 Cub Cadet 2544
    1979 Case 220
    2003 Yard Machines 17hp 42" transmatic (crap-matic)
Similar Threads
  1. NH TL90a PTO rattling problem
    By snowcrash in forum New Holland Owning/Operating
    Last Post: 11-23-2011, 11:26 PM
  2. NH TL90a PTO rattling problem
    By snowcrash in forum Parts/Repairs
    Last Post: 11-23-2011, 11:07 PM
  3. Power Steering Problem Not Solved
    By Alan L. in forum Kubota Owning/Operating
    Last Post: 03-31-2011, 06:35 PM
  4. L48 PTO Clutch RPM Problem
    By ChompinBrush in forum Kubota Owning/Operating
    Last Post: 12-01-2008, 11:32 AM
  5. cadet 1864 PTO problem
    By bobbybonds in forum Parts/Repairs
    Last Post: 05-28-2008, 11:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
