Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Gold Member
    Join Date
    Apr 2004
    Posts
    337
    Spencerport,NY
    Jinma 284
    Default Re: Changing blades
    Now if your LTX1040 is a 2009 model it takes special blades with a "special" star pattern as they only fit one way and have to turn 90 degrees from each other to keep from hitting.also they are torqued to 102 ft lbs. A real job without a air wrench.what is good is changing the spindle brgs.are real easy and cheap.
  2. #12
    Join Date
    Mar 2008
    Posts
    758
    Quote Originally Posted by mark1 View Post
    The _last_ tool I would choose to achieve 102 ft. lbs. of torque is an air wrench. You have no way of knowing/controlling actual achieved torque values whiile risking taking the fastener past it's rated clamp loading.... Use a calibrated torque wrench.
  3. #13
    Join Date
    Jun 2004
    Posts
    706
    Quote Originally Posted by rcbe View Post
    I've been using an air wrench for 34 years to change the blades since my first 1978 Cub 1450. I really don't think the torque is that critical as long as the blades are tight. Good luck removing the blades without an air wrench.
    Bob B.
  4. #14
    Join Date
    Mar 2008
    Posts
    758
    Quote Originally Posted by Bob_Bainbridge View Post
    Bob B.
    And I've been rejecting assemblies built that way since the '60s. One can use an air wrench to assist in breaking loose a stubborn tight blade fastener.. but _not_ to apply clamp loads during assembly.
  5. #15
    Join Date
    Jun 2004
    Posts
    706
    What does that mean? Are you an inspector on the Cub assembly line?
    Bob B.
  6. #16
    Join Date
    Mar 2008
    Posts
    758
    Bob B.
    nope. But, sure hope you ain't an assembler.
  7. #17
    Silver Member adjusterr's Avatar
    Join Date
    Oct 2010
    Posts
    236
    Western Maryland
    Kubota L2500 & 1010 John Deere
    I hook a good chain to the trailer hole on the rear of my JD mower, chock the front wheels and lift the rear of the mower up until I have easy access. I use a big C-clamp to hold the blades from turning and a long box end wrench to both loosen and tighten the bolts. I pull the bolts as tight as I can and have never had a loosening problem.
  8. #18
    Platinum Member Dr Dave's Avatar
    Join Date
    Feb 2012
    Posts
    849
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    I use my engine hoist to raise, impact off and impact on using a torque stick extension. They are a 8' long extension made out of spring steel, available in different torques, made for lugnut, they flex when torque value is reached.
    Dave
  9. #19
    Join Date
    Jun 2004
    Posts
    706
    It would be interesting to take a survey and see how many people use a torque wrench to tighten blades and how many just tighten them as tight as they can. I DID use a torque wrench on the cylinder heads but apparently MTD did not.
    Bob B.
  10. #20
    Gold Member
    Join Date
    Apr 2004
    Posts
    337
    Spencerport,NY
    Jinma 284
    As for me I've never used a torque wrench while putting blades on. The air wrench takes em off and puts em on. In my 55 years of messing with mowers if a air wrench was avail that's what has been used. Now I do have a very good torque wench and even had it's torque checked and calibrated years ago. I use it on things like heads and manifolds etc.but never blades. I've had friends get hurt trying to use a torque wrench on blades when the block they used to hold the blades slipped. etc.
Similar Threads
  1. Changing Blades
    By Mark Page in forum Owning/Operating
    Last Post: 07-27-2012, 03:46 PM
  2. Changing Blades
    By Fishguy 50 in forum Parts/Repairs
    Last Post: 06-11-2010, 08:00 PM
  3. Changing Blades - Need Help
    By jpmorgan12 in forum Cub Cadet Tractors
    Last Post: 08-02-2007, 10:56 AM
  4. Changing Chainsaw Blades
    By Billy_S in forum Parts/Repairs
    Last Post: 01-12-2007, 01:35 PM
  5. Mowing Changing mower blades
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 04-06-2003, 09:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
