Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Join Date
    Mar 2010
    Posts
    905
    Hayward Wi
    Kubota BX2230D
    Default Re: Changing blades
    I use my air impact to remove them and a torque wrench to replace them.
  2. #22
    New Member
    Join Date
    Jun 2006
    Posts
    5
    I made some ramps so I can drive mine onto my 4 post car lift sideways. Very easy to scrape the deck and take the blades off to sharpen.
    Changing blades-lift-jpg
  3. #23
    Gold Member
    Join Date
    Apr 2004
    Posts
    337
    Spencerport,NY
    Jinma 284
    Hey cohocarl Great idea..I have a 4 post but never thought of driving on sideways to do the deck.what's yer ramps look like?
  4. #24
    Gold Member
    Join Date
    Apr 2004
    Posts
    337
    Spencerport,NY
    Jinma 284
    hey Cohocarl great idea. I have a 4 post but never thought of driving on sideways to do the deck.
  5. #25
    Gold Member
    Join Date
    Nov 2009
    Posts
    331
    Wichita, Ks. metro area
    Kubota B1750HST
    For my Cub Cadet, I use my Mojack and an impact. An impact works best, just don't go crazy with it.
  6. #26
    Join Date
    Apr 2010
    Posts
    975
    Quote Originally Posted by rcbe View Post
    And I've been rejecting assemblies built that way since the '60s. One can use an air wrench to assist in breaking loose a stubborn tight blade fastener.. but _not_ to apply clamp loads during assembly.
    Even with these?
    10 Piece 1/2" Torque Limiting Extension Bar Set
    For years, I've just used "tighten until the fastener breaks then back it off a 1/4 turn.."
    Attached Thumbnails Attached Thumbnails Changing blades-image_13688-jpg
  7. #27
    New Member
    Join Date
    Jun 2006
    Posts
    5
    Quote Originally Posted by mark1 View Post
    You can see them in the lower right of the pic. I had some fairly thick plywood left over from a project (can't remember thickness), and made two triangle shaped ramps to get up onto the lift, then two boxes made out of the same plywood to go between the two beams on the lift that let me drive onto the lift until my front wheels are on the other beam. After it's on the beams of the lift, I swivel the front wheels around to give the mower a "longer wheelbase" (and make sure the brake is on!!) because I wouldn't want the mower to roll, or move off the lift while I'm under it.
    I scrape the underside of the deck with a short ice scraper, sweep out the droppings and I'm good to go.
Similar Threads
  1. Changing Blades
    By Mark Page in forum Owning/Operating
    Last Post: 07-27-2012, 04:46 PM
  2. Changing Blades
    By Fishguy 50 in forum Parts/Repairs
    Last Post: 06-11-2010, 09:00 PM
  3. Changing Blades - Need Help
    By jpmorgan12 in forum Cub Cadet Tractors
    Last Post: 08-02-2007, 11:56 AM
  4. Changing Chainsaw Blades
    By Billy_S in forum Parts/Repairs
    Last Post: 01-12-2007, 02:35 PM
  5. Mowing Changing mower blades
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 04-06-2003, 10:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
