Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    5
    Default kohler k301
    Any one have or know where I could get a connecting rod for a 12hp kohler k301 motor mine disintegrated
    Attached Thumbnails Attached Thumbnails kohler k301-forumrunner_20130116_021518.png   kohler k301-forumrunner_20130116_021541.png
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    May 2011
    Posts
    189
    NKY
    Yanmar YM186d,John Deere 1050, Case 211B
    Default Re: kohler k301
    Ebay has lots of them,and rebuild kits-cheap!
    JD1050,YM186D,Case211B,Homemade- sawmill & log splitter & log hauling arch trailer
    JD14T,Ford 532 balers,
    AC 80-R3,Ford 501 sickle mowers
    2.1 KW Off-grid Solar System and growing
  4. #3
    New Member
    Join Date
    Dec 2012
    Posts
    9
    Albion,NY
    Cub Cadet GT2550
    NAPA Auto PArts.
  5. #4
    Join Date
    Mar 2008
    Posts
    501
    OP - piston skirt appear to have been scraping cyl wall pretty good - might want to check all other areas (crankshaft) thoroughly for damage/wear. Kohler website has free pdf serv d/l manuals for those engines..
    Got yer manual ?
  6. #5
    New Member
    Join Date
    Mar 2012
    Posts
    6
    Ft. Wayne, IN
    CC127 & CC149, CCC 282 & WH656
    : It looks to me, that the piston has a chunk out of the skirt. Check crank, cylinder and cam for size and damage. If it has grenade gears, throw them away. Also while you have it tore down replace the govr'n gear. When I do a K-series, I use OEM parts. All though I did a K-301 for a Buddy of mine and he insisted that I use the kit from E-Bay. So for so good. and he is not easy on equipment.
Similar Threads
  1. Kohler K301 Rebuild - crank journal size
    By Al T in forum Parts/Repairs
    Last Post: 11-21-2012, 10:15 AM
  2. Wanted K301 Crankshaft
    By newfordguy in forum Private Party Ads
    Last Post: 04-05-2012, 12:47 PM
  3. John Deere 212/Kohler K301 Rebuild
    By jmcluka in forum John Deere Lawn & Garden
    Last Post: 07-07-2011, 07:41 AM
  4. Kohler 20 hp
    By gettingold71 in forum Parts/Repairs
    Last Post: 07-13-2009, 10:08 AM
  5. PT425 = Kohler Command, or Kohler Command Pro?
    By smartguyz in forum Power Trac
    Last Post: 06-30-2003, 05:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
