Results 1 to 5 of 5
  1. #1
    Silver Member kentuckydiesel's Avatar
    Join Date
    May 2004
    Posts
    138
    Default Cub Cadet 122...what would you guys do?
    Have my Great Grandfather's Cub Cadet 122 sitting in the garage. Engine is a K301AS
    About 15 years ago, a friend and I were doing some mowing at my Grandparent's farm. He was on the 122. He was going along just fine, then it suddenly shut off. We pulled it back to the barn and took a look. Appeared that the engine locked up (and it wasn't low on oil or anything). About 4 years ago I pulled it out of the barn, removed the head, engine turned over fine. No signs of carbon deposits or anything, but one of the valves was a bit sticky. Some Marvel Mystery Oil and a hammer handle got the valve working as it should. Got a new head gasket and put it back together only to find out that the starter/generator wasn't working. I moved back in town at that point and took the 122 back to my Grandparents place.
    A couple years ago, my Wife and I bought our own farm. Went back and got the Cub Cadet and started looking for parts to rebuild the Starter/Gen, but unfortunately that project always got put on the back burner. Finally about 6 months ago I decided to see if I could even get it running by using the Starter/Gen off of an old golf cart I have. I got it running, but it had to be choked or it would die. I let it run for a minute or two, then BANG BANG BANG....and the crankshaft hummed to a stop.
    I haven't torn it down, but it seems that the connecting rod let go.
    Here's my question. Do I rebuild the K301 or put a different engine in? It has been so long since I ran the little Cub, I can't remember if it had enough power or not. I have the ability to fabricate anything (I run a steel fabrication shop), so frame and driveshaft modifications are not an issue. I even thought of putting a 2Cyl engine in it.
    Ideas? Anyone put anything larger in one of these? Should I just rebuild?
    Thanks,
    Phillip
    SPIDER TRACTOR: '95 John Deere 5200 MFWD making around 60hp--12.4-24 8ply Goodyear R1 front tires--18.4-26 10ply Goodyear R2 fluid filled rear tires--Tires are set 8' 2" wide for maximum stability on hills--540 Loader with forks and custom fabricated bucket.
  2. #2
    Join Date
    May 2004
    Posts
    138
    Default Re: Cub Cadet 122...what would you guys do?
    ...or can I bore this 12hp engine and use the 16hp piston? All other specs appear to be the same.
    Thanks, Phillip
  3. #3
    New Member
    Join Date
    Mar 2011
    Posts
    12
    Lancaster, Ca
    Shibaura SD1843
    Cub Cadet 122...what would you guys do?-cimg1296-jpg
    Years ago, I had the Cub 100 that had a B&S L series 16hp engine in it. Had to lenghten the frame a few inches to fit it in. Ran great and had plenty of power. Probably used it for 10 years before i sold it.
  4. #4
    Join Date
    May 2004
    Posts
    138
    The 100 originally had 10hp, right?
    Do you remember if the extra power was worth the effort?
    Thanks,
    Phillip
  5. #5
    New Member
    Join Date
    Mar 2011
    Posts
    12
    Lancaster, Ca
    Shibaura SD1843
    Since the original 10hp motor was blown when i got it, I can't compare it to the 16hp motor. If you notice in the picture, there are dual rear wheels and there are wheel weights between them. My biggest problem was traction, even with the engine at an idle, doing any real work with it, the back wheels would slip. The 16hp never loaded down, I think it was worth the effort. I did have two hyd pumps on it, one in the front for the loader and one on the back of the engine for the rear blade lift. I had to have a custom clutch machined for it. You might be able find a replacement motor that would fit without having to modify the frame. Harbor Freight has some low cost engines that might work?
    Good Luck! Tom
Similar Threads
  1. cub cadet 122
    By cub 122 in forum Cub Cadet L&G
    Last Post: 01-06-2013, 08:59 PM
  2. cub cadet 122 rebuild
    By georgia plow boy in forum Cub Cadet L&G
    Last Post: 03-31-2011, 08:11 PM
  3. cub cadet 122
    Last Post: 09-08-2009, 10:05 AM
  4. 1965 Cub Cadet 122
    By ChrisJD4320 in forum Cub Cadet Tractors
    Last Post: 08-07-2008, 09:18 AM
  5. Cub cadet 122 Loader
    By yellowcub in forum Customization
    Last Post: 09-23-2006, 01:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
