Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Mar 2013
    Posts
    2
    Cumberland MD
    Cub Cadet 3235
    Default 3235 lift cylinder
    I have a 2004 Cub Cadet 3235 with a 291 deck. The lift cylinder is leaking off and the control valve is leaking at stem. Can the cylinder be rebuilt and control valve be rebuilt or are the replaceable only? The part number for the valve is 717-3452 and the part number for the lift cylinder is 717-3423.
  2. #2
    Join Date
    Mar 2008
    Posts
    758
    Default Re: 3235 lift cylinder
    A source like this: Cub Cadet 3000 series Tractor Parts might allow you to determine internal components - and if you are handy in hydraulics - let you rebuild your leaking valve and cylinder with fresh seals, orings, packing, etc.... or at least pursue competitive prices as I noticed the cylinder p/n was NLA at CC. Another option would be to take the leaking items to a hydraulics shop for rebuild....Good luck with your search.
  3. #3
    New Member
    Join Date
    Jul 2008
    Posts
    14
    I just did both on my 3235. The hard part is to get to the Valve, as far as cylinder that was fairly easy.
    Two O rings in the Valve, the cylinder a friend did for me.
Similar Threads
  1. Hydraulic Lift Cylinder
    By randall57 in forum Mahindra Owning/Operating
    Last Post: 10-30-2012, 12:12 AM
  2. Front-End Loader mf/32 loader lift cylinder
    By cwgarywi in forum Attachments
    Last Post: 07-17-2012, 01:05 PM
  3. Lift cylinder seals
    By Chris611 in forum Bobcat Construction Equipment
    Last Post: 08-13-2010, 12:45 AM
  4. Log lift cylinder
    By sly601 in forum Hydraulics
    Last Post: 04-12-2010, 09:01 PM
  5. Leaking lift cylinder?
    By MDM in forum Kubota Owning/Operating
    Last Post: 10-04-2007, 09:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
