Results 1 to 7 of 7
  1. #1
    Veteran Member Mickey_Fx's Avatar
    Join Date
    Aug 2005
    Posts
    1,132
    Vancouver Wa.
    Yanmar Fx24D, Cub 3204
    Default 3000 series availability
    Was doing some looking on the Cub web site and I no longer see the 3000 series machines listed under L&G. Next did a web search for these machines and that took me back to the cub site. Found some info but spotted a note saying limited supply.
    Has Cub dropped the 3000 series machines? Does limited supply mean they are drawing down on current inventory and then they are no more?
    Here's the link. http://www.cubcadet.com/webapp/wcs/s...00000_-1_image
    Yanmar Fx24D,
    Koyker 155 loader,
    RSB-1300 tiller
    Cub 3204, 48" mower
    Bolen 1257 GT with tiller
  2. #2
    Join Date
    Jun 2004
    Posts
    670
    Default Re: 3000 series availability
    Apparently since the Yanmar split they have dropped the 3000 & above lines and are pushing 2000 and Zero Turn mowers.
    Bob B.
  3. #3
    Join Date
    Mar 2013
    Posts
    127
    Connecticut
    L4600 Hst
    I was wondering what you thought of your Yanmar. I'm currently looking at the LX Hst4100 and cannot find much information since they are so new
  4. #4
    Join Date
    Apr 2013
    Posts
    58
    continental us
    all
    huh??? yanmar was not used in the 3000 series it was a price factor on this unit
    Quote Originally Posted by Bob_Bainbridge View Post
    Bob B.
  5. #5
    Join Date
    Jun 2004
    Posts
    670
    Quote Originally Posted by gladiater View Post
    Sorry if I confused you. I wasn't implying that Yanmar built the 3000 line but the Yanmar split and Cub dropping the 3000 line were near the same time frame.
    Bob B.
  6. #6
    Join Date
    Aug 2005
    Posts
    1,132
    Vancouver Wa.
    It's a shame they've dropped that series as it was/is a real decent GT. Guess I blame Cub/MTD for lack or proper marketing. There is room for more than just JD marketing models in this price class.
    I suspect this also means they've dropped their HD mower as they were shaft driven. At 265# they are a real bear. Don't know if any of the other mowers come with tapered roller bearings on the spindles nor offer all the grease fittings that are on these mowers. Remember when I was shopping for the tractor the dealer brought out the tractor with the std mower. Was early spring, grass growing fast and was over a ft. tall. The std mower couldn't handle the load and I mean the load would kill the engine. After some discussion dealer said they would swap out the mower for the HD model. A week later and grass close to 18", with the new mower, it cut the grass like a hot knife through warm butter.
    Have had this equipment for 8 yrs now and NO regrets.
    Yanmar Fx24D,
    Koyker 155 loader,
    RSB-1300 tiller
    Cub 3204, 48" mower
  7. #7
    Join Date
    Jun 2004
    Posts
    670
    I agree with you that the mower is a "real bear". I have a 2004 3235 with the 54 inch deck and leaf catcher. The old 1450 with 44A deck that I ran for 26 years had to have the deck removed and cleaned several times a year. My 1 acre yard has poor drainage and is often very wet. The 54 inch deck is almost more than I can handle (at my age) to remove, stand up on its side, and clean. It stays so clean that I've only had to clean it once every other year. Amazingly (knock on wood) it still has the original sealed battery. Last winter was the first year I decided to install a Battery Tender over the winter just in case. It has never failed to start in the spring.
    Bob B.
Similar Threads
  1. Looking at 3038, 3000 series, or 4000 series - your thoughts?
    By andrewj in forum John Deere Owning/Operating
    Last Post: 02-16-2013, 10:45 AM
  2. Comparison Turning radius: 3000 series vs. 4000 series
    By Honey Dealer in forum John Deere Buying/Pricing
    Last Post: 02-18-2012, 07:24 PM
  3. 3000 series or 4000 series?
    By fazel in forum John Deere Buying/Pricing
    Last Post: 05-25-2009, 07:19 PM
  4. Is the JD 4000 series much more stable than the 3000 series?
    By ArtVandelay in forum John Deere Owning/Operating
    Last Post: 06-30-2007, 01:07 AM
  5. JD 4400 series parts availability
    By Cactus in forum John Deere Owning/Operating
    Last Post: 06-05-2005, 07:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
