Results 1 to 3 of 3
  1. #1
    Member
    Join Date
    Sep 2004
    Posts
    39
    Default 3205 cub cadet question
    On my cub cadet, on rare occasions, the clutch pedal sometimes causes it to die. With the clutch pedal in normal operating position, it will sometimes cause it to die.
    By pusing in slightly on it, it will run fine. Normally, I can find a position where it will run and get past the problem.
    Does anyone know what to check for on this problem? Sounds like maybe a switch or something is being actuated.
  2. #2
    Join Date
    Mar 2008
    Posts
    758
    Default Re: 3205 cub cadet question
    yep, could be a switch acting up or a pc of trash caught up just wrong... or possibly a chafed elect. wire someplace along the clutch linkage that get moved/grounded every so often when the clutch linkage is worked. Might be worth your time to drop the deck and slide up underneath with a good trouble light and a helper to work that clutch where you can see in detail what all's going on...?
  3. #3
    Member
    Join Date
    Sep 2004
    Posts
    39
    Thanks. I'll do just that.
Similar Threads
  1. Cub Cadet 3205
    By Meistro in forum Cub Cadet L&G
    Last Post: 05-06-2013, 09:13 PM
  2. Cub Cadet 3205 - years built and quality?
    By bruceha2000 in forum Cub Cadet L&G
    Last Post: 05-03-2012, 01:49 PM
  3. Cub Cadet hds 3205 question....
    By flexmick in forum Cub Cadet L&G
    Last Post: 06-21-2011, 10:29 PM
  4. JD 425 or Cub Cadet 3205
    By Puddnhead in forum Buying/Pricing/Comparisons
    Last Post: 06-02-2011, 01:49 PM
  5. Cub Cadet 3205
    By wle in forum Cub Cadet Tractors
    Last Post: 04-21-2010, 10:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
