JohnMac
My cub cadet has a 13hp Kohler Command with the hydrostatic drive. It runs for maybe 10 minutes then stalls out. I've checked it afterward and there is no spark. It won't start again for hours.
I've read some of your older posts, and people with similar problems usually say it's either the ignition module or the ignition coil. I believe these are the same thing correct? If you think it is the module, would you recommend checking it first or just buying a new one? Any thoughts would be much appreciated.
