Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2006
    Posts
    83
    Default 3000 Series Deck Gear box Lube
    Iv'e got a 3000 series tractor and have both a 44" and a 54" deck I picked up this winter. I reconditioned the 54" deck over the winter and was going to check the lube in the gearbox but I can't find any information in either the owners or service manuals. Just to add to my confusion when I look at both gearboxes the 44" has the plug at the bottom of the housing and the 54" has the plug at the top. I'm guessing the 54" was put together wrong because that looks like it would be too much oil in the housing. I assume it's just a fill till the oil comes out of the plug, but just wondering what yours looks like (Plug on the bottom or top of the housing) and what lube you have used.
    Thanks
  2. #2
    Silver Member Rfisher7381's Avatar
    Join Date
    Apr 2011
    Posts
    113
    South West Michigan
    Kubota BX2360
    Default
    Usually there is a plug on the side which you remove. Then fill till it runs out. I use Mobil 1 75W90 in my kubota mmm gearbox.
    2011 BX2360, FEL, 60" mmm, 50" snowblower
    2004 Cub Cadet RZT50
    1994 Cub Cadet 1641, 48" mmm
  3. #3
    Join Date
    Aug 2006
    Posts
    83
    Default Re: 3000 Series Deck Gear box Lube
    Thats the same lube I use on the gearbox for my Woods 3pt mower, so I have it on hand, but on the 54" deck the fill point is almost to the top of the housing. Seems if I fill it to there its just going to foam up while my 44" deck with the same gearbox has the fill point at the bottom. One has to be wrong.
Similar Threads
  1. MMM Gear Box lube
    By Wyobuckaroo in forum John Deere Owning/Operating
    Last Post: 05-13-2011, 04:35 PM
  2. MMM gear box lube change.
    By dodge man in forum Kubota Owning/Operating
    Last Post: 05-26-2010, 07:08 AM
  3. Mowing Gear lube leaking on mower gear box out of vent
    By RMatty in forum Kubota Owning/Operating
    Last Post: 10-09-2009, 06:27 AM
  4. Cosmo 500, Gear Box Lube?
    By OkieG in forum Attachments
    Last Post: 10-04-2008, 10:51 PM
  5. Rhino Gear Box Lube?
    By VT365 in forum Attachments
    Last Post: 04-21-2008, 12:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
