Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jul 2015
    Posts
    3
    chittenango, ny
    CC 1320, 1641
    Default Cub 1641 Backfire/Pop Through Carb
    Hi and thanks for reading,
    I was mowing the lawn and the motor started to sound like it was missing, then stalled. I pushed it into the shed, removed the air cleaner, and the plate the air filter sits on was very wet with gas. It runs but misses, pops, backfires (but with no flames). It does not seem random. It has kind of a pattern to it. Any idea what would be causing this?
    Thanks!!!
  2. #2
    Join Date
    Mar 2006
    Posts
    978
    BEECHER CITY, IL
    KIOTI DK45S
    Default Re: Cub 1641 Backfire/Pop Through Carb
    You are running on one cylinder. Could be a spark plug wire shorting out, faulty plug, valve clearance issues. Just will need to start checking out things.
    ILLINOIS ENGINE, Beecher City, IL
    Briggs and Stratton MST (Master Service Technician)
    ILENGINE over at Lawnmowerforum
  3. #3
    New Member
    Join Date
    Jul 2015
    Posts
    3
    chittenango, ny
    CC 1320, 1641
    Thanks for the quick reply! It says 16 Hp on the air cleaner but no brand of motor. Any idea who make it?
    Thanks Again!
  4. #4
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,158
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Don't overlook the flywheel keyway.
  5. #5
    Join Date
    Jun 2004
    Posts
    670
    Quote Originally Posted by ggloob View Post
    Thanks Again!
    It's probably a Briggs & Stratton engine. It could be a blown head gasket.
    Bob B.
  6. #6
    Join Date
    Mar 2006
    Posts
    978
    BEECHER CITY, IL
    KIOTI DK45S
    From the short video I can confirm that it is the Briggs Vanguard engine. Model type and code will be either on a tag on the blower housing, or stamped into one of the valve covers. The vanguards will bend a pushrod now and again for no apparent reason, so that may be the issue.
  7. #7
    New Member
    Join Date
    Jul 2015
    Posts
    3
    chittenango, ny
    CC 1320, 1641
    So...to close, and not to leave this post open and unfinished (I hate it when people do that).
    RANDYT..You were right!!!
    And here is the reason:
    You can see the front rocker pivot was installed backwards.
    Cub 1641 Backfire/Pop Through Carb-100_0487-jpg
    And this was the result.
    Cub 1641 Backfire/Pop Through Carb-100_0488-jpg
    So I inspected the other cylinder, and both pivots were installed backwards! My neighbor bought this at a garage sale for a song and a dance. The seller said the top end was just rebuilt. I'm willing to bet that they just replaced the valve seals and screwed things up putting everything back together. I'm surprised he could even drive it off the trailer, let alone finish mowing half of his lawn. I think 4 new push rods and he will be back in business.
    You folks are the best! Thanks for the guidance!!!
    GG
  8. #8
    Join Date
    Mar 2006
    Posts
    978
    BEECHER CITY, IL
    KIOTI DK45S
    deleted
Similar Threads
  1. Backfire GT2544 Cub
    By budoinst in forum Cub Cadet L&G
    Last Post: 06-09-2015, 07:18 PM
  2. Cub Cadet 1641
    By corndodger in forum Cub Cadet L&G
    Last Post: 05-14-2012, 02:55 PM
  3. Cub Cadet 1641
    By NeedHelp in forum Cub Cadet L&G
    Last Post: 04-23-2011, 08:43 AM
  4. 1641 Cub Cadet
    By FxdGrMind in forum Cub Cadet Tractors
    Last Post: 09-28-2009, 09:09 AM
  5. Cub Cadet 1641
    By oldmanhartsboy in forum Cub Cadet L&G
    Last Post: 12-01-2008, 10:15 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
