Run Down.... just put on new carb out of Kohler factory sealed factory box....
old carb had stuck float....decided on new carb.
Engine started up almost immediately, and runs like a Swiss watch.
After....Tractor failed to start, and upon battery connection inspection...
positive cable broke in 2 pieces....due to corrosion....over the years.
Installed new positive battery cable end today.... and all's I get is
a click from the carb solenoid. Voltage is 12 at battery, and starter....but no drop
in voltage when key is turned to start. New cable end seems to be crimped tight....
but I am thinking, it is not crimped tight enough....or starter is bad ?
Any thoughts appreciated.
Pete
Hudson Valley , NY
Pete
Hudson Valley , NY
