cowboy2005
Member
- Joined
- Jan 18, 2005
- Messages
- 26
- Tractor
- Cub/GT-2544
I've been researching the lawn/garden tractors for a bit now and have really been impressed with the cub cadets. However, I'm a bit uncertain whether the 2000 series are worth the extra $1000 on average over the 1000 series counterparts (based on engine, deck size, etc).
The shaft drive vs. belt is obviously one of the more notable items, but is it worth it? I here that the replacement drive belt is around $25 and can last several years depending on use. Also the 2000 series indicate that they have welded frames. What does the 1000 series have in this case?!
My specific needs are for a lawn tractor that will last many (25+) years, cut lawn around an acre in size, pull a lawn plug style arreator and hold up to the rather hard and bumpy lawn I have. That's really my bigger concern as my self-propelled lawn mower really has takin' a beating from my lawn. Parts rattle loose, the wheels and other related parts need to be replaced every 2 or 3 years. Would a non-welded frame fall apart in a few years under these conditions?
Other then that, I can't see why the 2000 series would be desired. I do understand that the 1000 series really was created in the last 5 years to compete in the large retail stores, but does that mean they won't last?!
I was currently looking at the LT1046 or maybe the LT2180. Any thoughts or experience with comparisons of these two lines would be greatly appreciated.
thanks!
thanks!
