Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Oct 2007
    Posts
    23
    Default 2130 transmission problem
    I'm working on a 2130 AGS bought at auction with no documentation. I notice that the 6 speed gear box only has 5 gears. After removing the sheet metal, it worked in all six plus neutral. Apparently the slot in the fender prevents the shifter from going back into first or neutral. When the shifter is pushed all the way forward, it indicates 4th gear although it actually is in sixth. I see no adjustment in the linkage, and the shifter is keyed to the shaft. Is there any way to address this? Is there any adjustment available on the AGS gearbox? Everythings fits up perfectly except for the shifter position which I estimate is about 10 degrees off.
    - Mike
    CC/IH 1650
    CC1210
    Bolens 1257
  2. #2
    Veteran Member JTKub's Avatar
    Join Date
    Apr 2005
    Posts
    1,560
    West Falls, NY
    Cub Cadet Z-Force 44
    Default Re: 2130 transmission problem
    Is there any way to shim the fender assy. or open the 'slot' such that you can achieve all gears? Any way to bend the shifter rod?
    Joel
    Tractors of the past:
    2010 Cub Cadet Z-Force 44 fab
    2005 Cub Cadet 2544
    1979 Case 220
    2003 Yard Machines 17hp 42" transmatic (crap-matic)
  3. #3
    New Member
    Join Date
    Oct 2007
    Posts
    23
    I suppose I could cut out a longer slot in the fender and move the plastic gear indicator back, but that would be a real "brute force" solution. Same with bending the shift lever. What confuses the heck out of me is that everything fits exactly as per the construction diagram, and the shifter is still off 10 or so degrees. It makes me thing that either there is and adjustment somewhere I'm missing, or a incorrect part was used in the linkage.
    - Mike
    CC/IH 1650
    CC1210
    Bolens 1257
  4. #4
    Member
    Join Date
    May 2008
    Posts
    34
    Cub Cadet 2160
    Quote Originally Posted by MFP8055
    The speed control lever is connected to the gear shift bracket. The gear shift rod is also connected to the gear shift bracket. Is the gear shift rod in the top hole on the gear shift bracket?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
