Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Sep 2008
    Posts
    18
    cub 2160
    Default 2160 noisy deck - with sparks
    Getting sparks from blades obviously hitting something. Everything looks tight and I can't see where they are hitting, any suggested causes?
  2. #2
    Gold Member CCinCT's Avatar
    Join Date
    Mar 2006
    Posts
    280
    Default Re: 2160 noisy deck - with sparks
    Are those stock OEM blades, or replacement blades from another company. First guess is they're the wrong size and are hitting each other.
    Check the blades carefully for any signs of contact. If they're sparking, there will be marks somewhere.
    2006 Cub 2544 w/plow
  3. #3
    New Member
    Join Date
    Sep 2008
    Posts
    18
    cub 2160
    can't find anything at first glance with a light. Pulling tomorrow night for closer inspection. Belt off, all pullies tight. Can the blades overlap? These are non oe blades which have been on for at least 100 hours without previous incident. I usually sharpen on and lube a couple of times a season.
  4. #4
    Join Date
    Jul 2008
    Posts
    50
    NE Alabama
    Ford 3000, Cub Cadet 3186, Kubota BX1860
    Whew! It could be a hunnerd things....are there any baffles loose under the deck? Are the spindles tight? You mentioned noise....is it the pulley in the middle?? My 2176 had a bad noise from the pulley bearing going bad...a blasted CHINESE SEALED BEARING with no grease fitting. I replaced it and drilled out the cavity and put a grease fitting in it with timekin bearings....tremendous difference in the noise and cutting power! Makes no sense to put a sealed bearing on any of these things!
    I would look at these things first and then if nothing appears out of norm look farther....good luck.
  5. #5
    New Member
    Join Date
    Sep 2008
    Posts
    18
    cub 2160
    all good. carrier wheel mount on the front had cracked off and, when moving, would fall under the front of the deck and hit the blades. it was unnoticeable until the deck was removed. Straightened and welded back into place.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
